My ampeg svt 5 pro bassamp turns itself on and off several times until it warms up especially when its cold can you help please?
  • paulpondscum Nov 20, 2008
    I have the same amp and it does exactly the same thing. Quite annoying. If anyone has a fix, PLEASE post it.
    Thanks
  • zetalounge Apr 03, 2009
    Same deal, Turning itself on and off until warm. Fine after five minutes.
    New Friend:
Hi Guys,
Have a look here for a debug of this issue: YouTube - Ampeg SVT-5 Pro Problem YouTube - Ampeg SVT-5 Pro Problem
I recon two fixes are possible:
1. (Easy) increase the size of the heatsink on IC4.
2. (Hard) adjust the turn-on temperature of the fan by adjusting the control circuit.
I'm going to try 1, I'll let you know how I get on. my ampeg svt 5 pro - icon_tup.gif
Cheers,
Grant
Posted on Feb 19, 2010
SOURCE:
Hi, I have an Ampeg SVT 450 head, and I noticed that it squeals every now and then.
Duberney, there's just no way of telling anything regarding a unit's condition without examining the unit, however, what you're describing sounds like something in the chassis (around the power sec) is loose. Duh. The procedure to chase that sucker down requires a technician to fool around in there with the power on, so it's really not something that I would recommend an amateur do. I'm sure you would have no accidents - but it's just plain fun to see other people get electrocuted. Send me your city - I'll find you a tech.
Sep 19, 2018 | Ampeg Music
My buddy recently gave me his svt-6 pro amp head and there is barely any volume coming out of it when its cranked
Assuming you've tried other known working cables, speakers, and instruments, I'd suggest just taking it into a pro repair shop. If you start poking around inside without knowing what you're doing you risk frying the amp further or perhaps frying yourself.
Mar 08, 2016 | Ampeg Svt 6 Pro Amplifier
Ampeg b5r rack head squeals with low frequencies. when i wiggle the internal cable to the speaker out i preforms fine until i travel with it. plugging into an ampeg svt 610hlf classic
Sounds like you have a loose connection. Try re-soldering the
internal connection. and check the wire for breaks. it may be the cause of your intermittence. Good Luck!!
Apr 21, 2015 | Ampeg Music
How to replace an output transformer in an ampeg svt6pro
If you want to sell the damaged amplifier.
I'll buy you.
Apr 25, 2012 | Ampeg Svt 6 Pro Amplifier
I have had my ampeg svt 6 pro for a few years, never any problems until now. I just had a tone pot replaced. Now when i turn it on the fan is blowing at the max and the power light does not turn on and it...
first about the pop noise it caused by the Board inside the AMPEG need to be welding
second the power light simply check the 5v in your power supply
Jul 27, 2011 | Ampeg Svt 6 Pro Amplifier
Where can i get glass fuse for Ampeg 410hlf Mine is blown. It's the glass one for the tweeter
Radio Shack is usually a good bet, if there's one anywhere near you. Otherwise, go to their website, or check eBay and Amazon. If you can't find it there, you'll have to go to specialty electric/electronics vendors, like Shield's Electric or Graybar.
Jul 06, 2011 | Ampeg Svt-410hlf (4x10" 500w Svt Bass Cab)
I use an SVT450H with the SVT410E and the SVT15E both 8 ohm Ampeg cabs. I have to have the main gain on 5 to 6 and the master volume on 7 to 8 and that is in smaller venues. I use a 1964 Fender Jazz Bass...
Check to see the phasing of the two cabinets and the cable. Take a 9 volt battery and touch it to the end of a cable that is plugged into the cabinet. The + of the battery has to be on the tip, and the - to the sleeve. See If the speakers move outward. Check each cabinet if they do then they ae in phase. Now try it with the second cable the results should be the same. If not and they move in the opposite direction then that cable is wired wrong. If one of the cabinets move in the opposite direction than the cabinet is wired wrong. You can also run one cabinet at a time if they sound louder by them selves that should also tell you that something is out of phase.
Jun 17, 2011 | Ampeg SVT 450H Classic Series Solid state...
I have a Kenmore Series 80 Super Capacity Plus Washer. It has 3 water temperature settings, Cold/Cold, Warm/Cold, and Hot/Cold. Warm is Cold and Hot is barely warm. I know I have very hot water as the...
Sorry to read about your problem, I hope this helps you out.
the inlet valves just open and close, if you have high cold water pressure, it will override the hot water. I suggest you turn down the cold water valve, until warm is kinda warm. your cold water fills will take longer, but you will have warmer water
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Kenmore 24032\24036 Top Load Washer
Car hard to start on humid days
Just tuned up a jetta, put di-electric grease under the plug wire boots and especially the coil wire. The moisture causes mis-fire mainly at the coil. His VW had the same problem. Small pack of grease will be enough. buy 2 packs at adavance auto for $1.09 each.
Dec 31, 2009 | 1996 Volkswagen Jetta
Trans. shifting problem
try a fluid and filter change and also a modulator valve and make sure you have vaccume going too it
Feb 27, 2009 | 1995 GMC Sierra C1500
795 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
