Question about Vizio VX32L Television
My TV has no signal with a blue screen need to know the settings and trying to watch the fight (boxing). No picture at all just say's no signal.
    Top Expert:
  • Vizio Master
  • 14,553 Answers
Is the problem there on all inputs? Cable, component, HDMI etc?
If the set works on any input it is not the problem. If you are using a cable or Satellite box it may be not connected correctly or have a problem.
Give me as much information as you can so I can assist you.
I am here right now to help you.
SD TECH
Posted on May 02, 2010
It has "V1.43 Pace PR150BNM SysCode Loader" Pace. Across the top of blue screen, what's up?
Element Electronics blue screen no signal Questions ... - Fixya
www.fixya.com > Forum > Tags > blue screen no signal
Blue screen with ''component 2'' in a box shows. Then it goes black.There is also a humming coming from the tv. I have unplugged everything from the tv, and ...
element tv problem - YouTube
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
... is a vid im attaching to my email to custamer support to try and fix my bad tv. ... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW ...
Dish Network - My element TV is saying "no signal". ' Directly
Jan 09, 2016 | Element Televison & Video
NO PICTURE
Refer to the manual (free download here). Generally, a blue screen indicates a very low or non-existent signal. This can happen when the antenna is unable to gather enough of a signal from a particular broadcaster, or if an A/V input is selected, but the A/V device is not on or providing a signal. Since you are not seeing channel information when tuning, I suspect that the television is set to display an A/V input instead of the internal tuner.
With a working remote, locate the TV/AV button on the lower left (manual page 3 - item 8). When this button is pressed, you can choose to display signals on the ANT, VIDEO1, VIDEO2 or COMPONENT jacks. The ANT selection chooses the input on the RF jack such as an antenna or cable TV (with or without converter box). If using a cable box, the TV tuner should be set to Ch3 or Ch4 as determined by your cable box. Otherwise, select the VIDEO1, VIDEO2 or COMPONENT input that has the source signals you wish to watch from a cable box, DVD player, etc. that is connected to the rear input jacks. Page 7 of the manual details the connection and remote operation.
I hope this helps!
Apr 16, 2012 | Insignia NS- 27" TV27 TV
I have a 42inch lcd polariod tv and the screen comes up blue no picture or sound
It could be the blanking circuit displaying a blue screen if no or a weak signal is connected to the TV. If you have a DVD or VCR try to see if you get picture and sound when ether of those devices are connected to the auxiliary input. If yes your signal input is weak, or you are getting no signal at all. If you go into the TV do you see text? If yes make sure you’re on the correct auxiliary input. If no text is visible the problem is internal and the LCD driver circuit needs to be repaired. If you see text and you are on the correct auxiliary input, but you get no picture and sound then the problem is internal and the front end tuner needs to be repaired. If you see video and hear the sound make sure your channel is correctly selected and set to a working channel. If you have a cable box remove the input to the box and connect it into the coaxial input on the TV and see if you have a picture and sound. If you do the cable box is defective. If you do not see any channels the cable may have lost its signal, and you should connect the cable to another device to check the signal quality. If you have a satellite service provider, and you use a known working device to check the signal and the device works then the TV needs to be serviced.
Feb 18, 2010 | Polaroid Televison & Video
Blue screen: Not Support!
It sounds like you have no signal being detected by the TV. Check your connections to the TV from your cable box or satelite reciever to be sure they're plugged in tightly. If you have a DVD player or VCR, try watching something from one of them to see if you get a picture. If you do, then your problem may be with your cable box or satelite reciever, and not the TV.
Good luck.
Dec 01, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Rca 20F514TD blue screen
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 05, 2009 | RCA 20F514TD 20" TV
Blue screen
it is not seeing a signal source.in the earlier days,"snow" would be evident but today the tuner signal lost results in a blue screen.check the cable signals and the cable box.
i would put cable from the wall directly into the set and see if there is a picture,and then check that it is not set to aux input with nothing connected
Aug 18, 2009 | Sansui DTV2760 27" TV
Sony Wega Trinitron HDTV Blue Screen with Sound
Had similar problems with HD cable on dvd. swapping with another cable solved the problem.
Aug 11, 2009 | Televison & Video
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
Jun 26, 2009 | Hyundai Electronics E465D 46 in. LCD TV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Blue Screen Issue
try hooking all systems involved to the same electrical circuit, using a power strip if neccessary. also check your big screen and other equipment and make sure that any polarized plugs are in correctly. if you are an electrician, or know one, check the circuits that you're using to be sure the outlets are wired correctly. if the ground, neutral or power are not wired to the outlets properly it will seem to work, but not right. check the "cable line in" at the ground block with a multimeter for excessive power or get a qualified cable tech to check. when you touch the cable coming to the box or the tv and also touch the cable in do you feel a tingle? if so, it is most likely a power issue as mentioned above.
Apr 28, 2008 | Televison & Video
Vizio VX32L Television Logo
108 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
