Fisher & Paykel Smart Drive 703, sometimes will not start a cycle and stop and starts as it pleases throught out the cycle. has now stopped on spin cycle and will not restart.
  • 5 more comments
  • Edward Roy Iwanowski May 02, 2010
    All the lights stay alight at the time it stops and none of them flash which is why we cannot ascertain the problem. Thanks.
    Where it ha stopped now. Only light no. 8 SPIN is lit and it is not flashing.
    I have tried this before, but unplugged the machine again for much longer than 10 minutes. When turned back on and power button is pressed , all lights come on, none are flashing and when start is pressed nothing happens, when pressed again the most left light flashes, as it does when cycle is paused, and when pressed to continue the cycle doesn't proceed.
    Where can I get a copy a manual for a Fisher & Paykel Smart Drive 703?
    I have held the wash temp down button & pressed power. the panel lights up but the machine does not beep.
    I pressed the spin speed button up 3 times ( did beep at each press), hold & Slow lights illuminated but there were no LEDs on the wash progress panel to read the fault code??
    Thank you. I unplugged the machine for a while and it is now working! I completed the spin cycle where it was stuck and have almost completed another load without any problems. There is just the spin cycle to complete. The model that we have is a Fisher & Paykel Smart Drive 703. Our next question was going to be 'do you know where we could get a manual?', so if you could let us know where we could download one from we would be very greatful. Thank you so much fo you help today.
    Excellent...Thank you.
    President:
  • 1,554 Answers
Please indicate what among the Wash Progess LEDs are lit or flashing as it indicates a fault code which will determinate what is the cause of the problem. The washer has a restart feature that allows it to correct the fault first before flashing the code. That is why it stops and then restarts.
Posted on May 02, 2010
  • 4 more comments
  • Jahn27
    Jahn27 May 02, 2010
    From left to right and numbered 1 to 8, indicated which among the LEDs are lit or flashing.
  • Jahn27
    Jahn27 May 02, 2010
    The restart feature is most likely turned off as indicated by the lighting up of the 5 leftmost Wash Progress LEDs. Unplug the washer for at least 15 minutes to reset the control and turn on the restart feature.
  • Jahn27
    Jahn27 May 02, 2010
    It is fault code 1 and indicates a motor controller module failure in you phase 3 washer. Check the connections between the display the module and the motor controller module. Make sure the connection is good and snug fit. Replace the motor controller module if the problem do not cease to exist.
  • Jahn27
    Jahn27 May 02, 2010
    The lit Spin LED indicates fault code 1 on your washer which signifies a bad motor controller module. The last fault can be found by entering diagnostic mode then pressing the Spin Speed Up button three times. Enter diagnostic diagnostic mode by pressing and holding the Wash Temp Down button then the Power button until the machine gives 2 short beeps and lights up. Press the Spin Speed Up button three times then the Hold and Slow lights should be illuminated, and then read the fault code from the Wash Progress LEDs. Make sure to unplug the machine first then replug it before turning it on by pressing the Power button.
  • Jahn27
    Jahn27 May 02, 2010
    With the Hold and Slow lights lit, it indicates the diagnostic mode has been entered successfully but the failure to display the fault code signifies a failure in either of the display module and the motor controller module. Please indicate the exact and complete model number of your machine.
    The lit Spin LED you posted previously indicates a failed display module for Phase 1 machines and a failed motor controller for Phase 2 and above machines.
    I have the two service manuals for these machines and I can upload it, but not here, for you to download. Just make sure to download and save it within the next 4 hours because I will be going to deactivate the link after that. And giving you the manuals would mean you are going to accept and rate the solution provided.
  • Jahn27
    Jahn27 May 02, 2010
    Here are the service manuals for the Smart Drive and EcoSmart Fisher and Paykel Washers. Download it within the next 4 hours. Please accept and rate the solution provided. It's a pleasure to help you and thanks for using Fixya..
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
I have an toploader smart drive (about 12 years old now). I added some clothes to the machine last minute throught the cycle and now its just stopped. Dashboard lights come on but it wont drain or...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 21, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Hello where can I find the error codes for a fisher and paykel smart drive 703? It stops usually during s pins cycle (well it looks like it's trying to spins and it won't start).so it stops and...
Hi - what would youlike to know - we are forbidden by contractual & copyright laws to provide what you seek..
Besides you are lucky if parts for the 703 is still in existence - only savvy techs could salvage those as you have to modify wiring & components for it to work. I have only done this once in the Pacific islands some years ago.
Jun 24, 2011 | Fisher and Paykel (IWL12)
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel GW 703-U water flow and the engine sounded choked
sounds like out of balance switch is faulty. does the water start stop start stop then machine beeps. if it does it is most likely out of balance switch.please reply 4 more help
Mar 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine
motor is starting to wear out ,replace it .
Oct 01, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
135 people viewed this question
Top Washing Machines Experts
