Question about Bosch WFK 2401
How do I remove the belt that goes from the motor to the durm on a wfk 2401 washer
  • r_pforman May 02, 2010
    Thank you. This is the information I needed. So, there is no way to set the tension?
  • goggomobil May 11, 2010
    To access it, the rear panel must be taken off. If you are asking how the belt is removed from the pulley, pull the belt firmly towards you and rotate the large pulley with your other hand, being careful not to pinch your fingers that are gripping the belt. Do this until the belt is unseated from the grooved pulley.
  • Bosch Master
  • 2,605 Answers
Hello, It should be relatively easy. Turn off the circuit breaker at your home service panel first, but leave the unit plugged into the outlet to insure it remains "grounded" as these are very vulnerable to "ESD" or "elecro-static discharge". Unplug it ONLY if you are grounded or not sure of which breaker but make sure you are discharged of any static. ( wear a grounding strap is recommended ) I'd hate to see you injured or repairing electronic boards etc. Now you can remove the back panel and spin the belt off as you turn the large pulley ( for the basket & not the motor, this gives you the mechanical advantage ) as you would a bicycle chain. Be careful not to pinch you skin/fingers. Let me know how you make out or if you require further assistance. Please take second to rate the instructions accordingly. Thank you for visiting "fixya" for you repair inquiry and good luck. Macmarkus :)
Posted on May 02, 2010
  • Mark MacDonald
    Mark MacDonald May 02, 2010
    Hello again,
    On the "WFK" models there is no tension-er or adjustment, the belt is built to spec to fit tight. If it seems loose it is stretched and needs to be replaced.
    hope that help's move you forward. Let me know how it goes or if you need any further assistance.
    Also, If you'd like a complete repair manual in "pdf" format I can send it to you but I'd require an email address. It is actually for the "WFL" & "WFR" generation machine, but the drive system is pretty much unchanged, as is the rest of it and It is 6.88MB in size.
    Let me know and Good luck
    macmarkus :)
  • 273 Answers
With the back panel off, pull the belt towards you whilst spinning the large pulley. Be careful not to pinch your fingers. Keep doing this until the belt gradually moves over and off of the large pulley. It goes on the same way. Sorry if this is a double post.
Code 08 on bosch wfk 2401
Faulty door switch
Aug 27, 2014 | Bosch WFK 2401
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Bosch wfk 2401 drive belt slipping
If you are certain that it is a belt problem and not a motor one, you need to purchase a replacement belt (the same applies if it IS a motor problem- change the belt at the same time!)
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. Ours for a Bosch cost GBP250- but it's your choice!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 06, 2011 | Bosch WFK 2401
Our 9 year old WFK 2401 needs >$900 repair (drum bearing bad=needs both inner and outer drum; pump motor squeals.) But dealer says we must replace BOTH washer and WTA 3500 drier (which if fine) because...
yes he is right!!! ask yourself this,,,,after 9 years have you had your money worth out the dryer yet? and the washer???
go on treet yourself,,,buy a new lot,,,you know you wont to?
and what a slap in the face for all your friends,,,"look what i got!"
rasssssp!
Aug 28, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Changing bushes on bosch classixx1200
To change brushes in Bosch motor.
Remove rear panel of washer, undo 2 screws that secure motor at front end, remove motor plug, lever motor back with a screwdriver or similar, and remove motor retaining a hold on it,\ so as not to drop it .
Replace brushes fitted at rear end of notor.
Refit motor and belt.
Thanks.
Jan 08, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Washing Machines Logo
95 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
