I just want to get the manual for the board so that I know what is what on it. If someone can tell me how to install a graphics card (progably GForce 2 or higher) onto this board that is now using the onboard video system and won't play many games that I install. I do see where the card will fit on the board. The computer OS (win XP) will take the install but won't play the game because the graphics card is missing or unsuitable.
I want the manual and info on the graphics card installation location, please.
Thanks
Comments:
Mar 27, 2008
- I guess you didn't see the first line of my post, "I just want to get the manual for the board so that I know what is what on it."
Thanks, though, for the info on installing the graphics card.
-   the only issue is... is that dell does not have the manual for the bord on their site.
i got the bord as a present from my boss and im having ram issues so im also looking for the manual
-   Guest
Aug 29, 2008
-   my sound drivers!-   Guest
May 18, 2008
-   I've always the second time booting a "previous shutdown due to a thermal event". The fan is working. I've no idea. Can you help me? PC= OptiPlexGX270. Please answer to hartmut.niesenhaus@gmx.de
-   happu
It will go in any PCI slot.When you boot the machine it should come up with found new hardware wizard.Follow instructions.If new hardware wizard does not pop up go to control panel,then dbl click on add new hardware and follow prompts,it will ask if you have the disc if you dont it has options for what hardware you are trying to install.If you do have the disc you can put the disc in the CD dirve and it should automatically start,if not click on my computer dbl click your drive where you put the disc and when the program opens click on install,
Comments:
Apr 18, 2008
- look for the manufacturers name and version number on the board and go to their website,sometimes you can find the info there.
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet,...
(More)
Ik heb geheugen bijgestoken, deze zijn correct, nu start pc niet meer op, f2 of booten helpt niet, ik trachte ook met opstartschijf.... Ik zie dat bios/cmos? niet opstart, op mijn scherm krijg ik enkele seconden "in power safe mode, press any key" ik probeerde al veel, batterij eruit gehaald en vernieuwd, videokaart gewisseld, scherm gewisseld, alle plug ins nagekeken,enz.... Kan iemand zeggen wat er aan de hand is en hoe ik het kan verhelpen, ik trachtte ook het oude geheugen teurg te plaatsen, dit zonder resultaat mvg Jan
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard...
(More)
Display only shows low 8 bit 800 by 600 Cant get on internet on this machine so need motherboard drivers to download direct so i can put on disc to correct
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan...
(More)
necesito saber el numero impreso del circuito Q8F1 de la tablilla dell E210882. si alguien es tan amable de pasarmelo se lo voy a agradecer mucho.
