Question about Family Care HAP1004 Air Purifier
Filter replacement I can't get a filter where I used to purchase them. Where can I get one now. I keep getting a message that it is a discontinued item
  • 1 more comment
  • Anonymous Apr 13, 2008
    I need a replacement filter too. I get the same message from Walgreens.com. Let me know if you find a place to get them.
  • Anonymous Jun 13, 2008
    SOMEBOBY HAS TO MAKE A FILTER THAT MATCHES! IT'S UNFAIR TO SALE A PRODUCT; THAT NOW I CAN'T USE.I WENT TO THE WALGREEN WHERE I PURCHASED IT SEVERAL TIME, EACH TIME TALKING WITH SOME ONE DIFFERENT.
    SOMEBODY, PLEASE HELP US.
    MACK
  • Anonymous Sep 30, 2008
    same problem. dirty filters b/c I can't find the replacements at Walgreens where I bought them.
Here is the part number for that model.
Arm & Hammer® Odor Grabber™ Filter - AORF9PF-U.
Sue
Posted on Apr 09, 2010
Hunter air filter when you turn it on it keeps cycling- on/off,on/off and wont stay on. also hepa filter button not working any more, does not light up blue when pressed. TY for any help : )
Hello, this is Ava with Think Crucial.
If your unit has a reset button, try resetting your unit. Also, replacing the filters and resetting it after putting on the replacement filters usually works. If this fix doesn't work, I suggest you contact Hunter support for assistance and their number is 888-830-1326.
You can purchase a wide variety of high quality Hunter replacement parts for your Hunter Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=hunter
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 01, 2016 | Hunter Air Purifiers
Tip
Air Purifier Cleaning
You bought that air purifier to help to clean the air in your home. However you have forgotten about it and now you expect it to still clean, when all of the cleaning surfaces and the filter that catches the big chunks are completely used up and covered with dust and dirt.
Here is what you need to do on a regular, like monthly, basis to keep it working well.
  1. If your unit has a filter or pre-filter pull it out and wash it gently in some warm soapy water. If the filter is a throw away one then place it in a plastic bag and dispose of it. Be careful not to throw it away before you make sure you know what to get to replace it. You may need the old one for comparison when purchasing a new one. Also take note of how you removed it and the direction of the air flow. Some of the filters are made to have the air flow in a certain direction. The filter is often located in the back side at the bottom of the unit.
  2. Take apart everything that you can on the air purifier and clean all the pieces with a moist cloth. You may need to take toothpick or something small to clean out the small grooves and crevices in the unit.
  3. Leave everything dry completely before reassembling the unit. This may take quite a while for some of the filter media. A few hours is not uncommon, be patient.
You now will have your air purifier working in top condition again
on Jan 11, 2010 | Air Purifiers
Red light keeps blinking
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
Ava B.
Aug 24, 2014 | Holmes Products Air Purifiers
Can't find ORECK filter #AT2PK, been waiting for months for the ORECK store to get them. WHY!!!!!!!!!!!
They discontinued it. Just go to any aquarium and buy a carbon filter pad and cut it to size. They sell big sizes for under $10 and just stick it in your Oreck Air 5 air purifier. Works just as well and cheaper!!
Aug 27, 2013 | Oreck Air Purifiers
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
I HAVE THE FRESH AIRE MODEL JUST REPLACED rci CELL CLEANED FILTER AND CLEANED THE OZONE PLATE. THE FAN KEEPS TURNING ON AND OFF?? STARTS RIGHT BACK UP ON ITS OWN AND THROWS NO EROR MESSAGES??
The main circuit board is probably bad. It seems Ecoquest installed a number of them that have a problem. If the machine is under warranty, they will replace it if you pay shipping. Otherwise, you'll have to pay the whole bill. Either way, call first to get and RMA number.
Nov 23, 2009 | Ecoquest Air Purifiers
Is this a good model # for a GE electrostatic air cleaner/filter. If so, are parts still available for it? Model #BEF28009 (I.D. tag is hard to read?)
not likely the electrostatic air cleaners are discontinued for the most part because the really didnt do all they claimed. you can achieve much better air quality from a standard media air filter with a merv rating of 10 or better.
Sep 11, 2009 | GE Air Purifiers
Family Care HAP1004 Air Purifier Logo
233 people viewed this question
Top Family Care Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Family Care Air Purifier Expert? Answer questions, earn points and help others
