Question about Acer Aspire One PC Notebook
BIOS Update, Flash??
BIOS Update, Flash possible ??
  • Acer Master
  • 1,606 Answers
If there is a bios update available you can just download it from the Acer support page for your laptop. These are usually a windows based program these days so youjust save to your desktop, turn off every thing and close all the programs, make sure the power adapter is plugged in and run the update. Let it run and it will reboot or ask you to when done and thats all there is to it.
http://support.acer.com/
You will need to know your model number ie AO532 and then just click on the bios tab when you get to your model page and downlaod the files. There are some updates to fix the touchpad and other things. Just use the latest date and you should be good.
Posted on May 02, 2010
  • Acer Master
  • 8,404 Answers
Is there a good reason to flash your BIOS? You have a good chance of ruining your computer ... is it worth the risk?
If there is a update ... of course it is possible. Acer has a good section on this process.
Black screen
Aspire notebooks are designed with personal entertainment in mind, but when your monitor blacks out after only a few minutes, it's somewhat difficult to be entertained. There are several potential causes, as well as a few different ways to fix this problem.
Possible Causes This problem can be caused by your laptop entering sleep mode, overheating, damaged or faulty components, an improperly seated monitor cable, low battery and/or screen resolution set outside the monitor's range. Sleep mode is the most likely culprit, particularly if you're using your laptop on battery power. b> Prevention/Solution Sleep mode settings are located under "Power Options" in the Control Panel. Damaged components can be replaced by Acer if you send your Aspire in for repair. Routine cleaning of the exhaust ports and upgrading the cooling system can fix overheating. Plug your laptop into a wall outlet via the adapter to see if low battery power is the problem. Boot into Safe Mode to adjust monitor resolution if you can't do so normally. b> Considerations Acer will typically provide service for damaged laptops under warranty, typically for only the cost of shipping. They can also repair computers which are no longer under warranty, though you'll have to pay the full price for servicing. You can open a ticket with the support department to try and determine what your problem is as well. A recall has been issued for Aspire models AS3410, AS3810T, AS3810TG, AS3810TZ and AS3810TZG made before September 15, 2009, because of a problem with the microphone cord that causes overheating if pressure is applied to the left palm rest.
http://support.acer.com/ acer sup
One of the most common ways to update (or "flash") the BIOS on a computer is by using a standard USB flash drive. If a new update is available for your BIOS, you'll need to flash it to update it. Short for "basic input and output system," the BIOS is the main program on your computer and will periodically need to be updated to ensure that your machine stays functioning the way you want it to. Though it is an incredibly important procedure, updating the BIOS from a USB flash drive won't take more than a couple of minutes to complete.
Insert the USB flash drive that you want to use to flash your BIOS into your computer. Download the update for your BIOS from the website of your BIOS manufacturer. (The manufacturer of your BIOS will be listed in the instruction manual that came with your computer.) Copy the BIOS update file onto your USB flash drive. At the same time, make a note of the exact name and extension of the update file. Do not remove the USB flash drive from your computer. Restart your computer. Press the key required by your computer to enter the BIOS. This key will be written down on the screen. Press this key immediately as your computer starts to turn itself on. Highlight "Boot" and then hit "Enter" to select it. Change the piece of hardware listed under "Primary Boot Device" to reflect your attached USB flash drive. This will tell your computer that you want to restart your computer and boot from the flash drive. Select "Save Changes and Exit" to restart your computer. Wait a few seconds for a command prompt to appear on your computer screen. The command prompt is an entirely black screen with a small line of white text that you can type on. Once the command prompt appears, type in the name of the BIOS update file on your USB flash drive. Then hit "Enter." Hit the "Y" keyboard key a single time to tell your computer that you want to update your BIOS. Your existing BIOS version will be upgraded (or "flashed") to the new version via the file on your USB flash drive. Do not remove the USB flash drive from your computer during this process. Remove the USB flash drive from your computer once the BIOS update process is finished. The update program will indicate when the process is finished. Your computer will automatically restart itself and your BIOS will be updated. Bios definition http://www.butterscotch.com/tutorial/What-Is-A-BIOS
Apr 11, 2013 | Acer Aspire One D257 Netbook
Bat bios checksum problems solve
Step 1:
Update ASUS BIOS b> Insert bootable floppy disk or USB drive. Copy the updated BIOS file to floppy disk or USB drive.
(Note: BIOS file and boot files should fit on a floppy disk. If the BIOS file is too large to fit with boot files, consider using the EZ Flash method described below.) Insert the motherboard support CD into optical drive. Copy AFUDOS.EXE from CD to a floppy disk or USB drive. Reboot. When the DOS prompt appears, type the following: afudos /i[name of BIOS file]For example, "p4c800b.rom" might be the name of the new BIOS file. "afudos
/ip4c800b.rom" is the command that will install it. Wait. Your monitor will display the update's progress with a series of messages: "Reading file," then "Erasing flash," then "Writing flash." The "writing flash" message will be followed with a percentage counter that tells you how far the write has proceeded. The final message will be
"Verifying flash." DO NOT switch off or reboot at any point in this process or you will ruin your motherboard. After the update is complete, the utility will return to the DOS prompt. Remove your floppy disk and reboot. Enter the BIOS Menu and load "Setup Default." Save and reboot. You're finished. b> Update Using EZ Flash Copy your new BIOS files to a floppy disk or USB drive. Reboot. When the system is at POST, press "Alt" + "F2" to enter EZ-Flash. Alternatively, on late model motherboards you may press "Delete" to enter BIOS setup, then access EZ-Flash from the "Tools" option on the navigation bar. (Select Tools > ASUS EZ Flash 2 > YES) Wait for your system to check current BIOS information. Insert your floppy or USB with the new BIOS file. Select the drive letter with the BIOS update file, then select the file. Wait for your system to check the update file. After the file check is finished, click "Yes" to update your BIOS. Wait. Let the update procedure run until it finishes. Do not switch off or reboot or you will ruin your motherboard. When the update is finished, remove the floppy or USB drive and reboot. Enter the BIOS Menu and load "Setup Default." Reboot. You're finished. b> Update Through the Internet If it isn't installed already, install the ASUS Update utility. You can either download it or use the copy on your motherboard's support CD. Close all Windows applications if any are running. Launch the ASUS Update utility from the Windows desktop by clicking "Start>Programs>ASUS>ASUSUpdate>ASUSUpdate." The "ASUS Update" main window will then appear. Select "Update BIOS" from the "Internet option" drop-down menu. Click "Next." Select the ASUS FTP site nearest you, or choose "Auto Select." Click "Next." From the FTP site, select the BIOS version that you wish to download. Click "Next." Start the update. Wait for it to complete.
http://support.asus.com/technicaldocuments/technicaldocuments.aspx?root=198&SLanguage=en-us
Feb 05, 2013 | ASUS Eee PC 900 Notebook
I want upgrade bios ga 8simlh rev 1.0,but can not
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
Where to download drivers to update the BIOS for my IBM desk-top
Ha! Old OS, old URL; possibly just an old desktop not up to the task of running WinXP.
It's a new BIOS you'd flash your system with, and probably a push between your motherboard's BIOS having an update (you'd go to the mobo's maker's site, e.g. that of ASUS, Gigabyte, Intel, etc.; read the screen-print on the board; to get the update) and telling WinXP to install anyhow using a handy force-install option.
May 02, 2010 | Computers & Internet
How to copy a flash bios in supermicro motherboard model p4sba+ ? i have 2 units motherboard pc model p4sba+, 1 unit have problem of bios flash, & the other unit is working well,is it possible to copy...
You first need to BIOS Wad possible anaphylactic posted on the company and then, You will need a device for downloading revolved around the BIOS on the flash and the device is in the market prices and different types of
Apr 19, 2010 | SuperMicro P4SBA+ (MBDP4SBA) Motherboard
I did a bios flash update on my hp laptop.windows not installing!
wrong BIOS
you are dead in the water, the laptop is dead. unless you can get another same motherboard and swap the BIOS.
other choice is to install your OS from the begining, if the laptop let you into the BIOS.
May 15, 2009 | Computers & Internet
Problem with my ibm300PL BIOS
nvjt58a.exe 1,050,983 Flash BIOS update
nvjt58a.txt 17,012 README for the Flash BIOS update
Oct 29, 2008 | IBM 300PL (PC 300 PL 733) PC Desktop
Bios update
if you can use another pc and reinstall the previous bios flash it from floppy this should sort out the problem
or you can try and flash the updated one again if this fails
then you need to contact the manufacturer for a possible bios chip replacement
hope this helps !
Nov 05, 2007 | Gigabyte GA-7VA Motherboard
Acer Aspire One  PC Notebook Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
