Question about Refrigerators
Hotpoint HSS25IFMA side by side
My Hotpoint Side by Side started making a loud noice this weekend. It sounded like something was vibrating with a piece of metal on top. Fist I thought maybe something had fallen beside or behind the frig. Nothing in sight then I noticed you could make it quit by opening either door. There was also a little water on the floor when I came back in the room from under the freezer side. I had also been noticing ice inside the freezer box, some in the case just above the top of the door and some also on the top inside ledge of the door.
Anyway, I scheduled G.E. service to come, the service man said that the doors were defective and it would cost $650 to replace them. Has anyone ever heard of this befoer or does he think i was just born yesterday???
SOURCE:
  • 1462 Answers
SOURCE: Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Posted on Jul 13, 2007
  • 22 Answers
SOURCE: Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Posted on Nov 13, 2008
  • 4 Answers
SOURCE: side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Posted on Apr 19, 2009
  • 245 Answers
SOURCE: noise vibration
if you take the back panel of the freezer out you can get to the condenser fan they do have a habit of going bad and actually having the fan and shaft move forward on them usually when you start hearing the noise it is not long before it goes out completely.
Posted on May 15, 2009
  • 4793 Answers
SOURCE: Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Posted on Feb 06, 2010
Hello, \r\nI have a 2003 dodge neon SE. I hear a loud roaring noice and vibration from the front end, the noise is really loud (like a truck) when I start it. When Car in drive the noice is loud but when I...
Hey Shona... Please take your car to a qualified professional... this could be something very serious related to safety.. do not take a chance.. let them diagnose your problem..please...
Jul 14, 2017 | 2003 Dodge Neon
I HAVE A wailing HOTPOINT HSS25GFPH WW refrigerator
change the rubber isolating washers on the pump and compessor too hard a compound will make things worse ,neoprene works best ......
Feb 07, 2010 | Hotpoint HSS25GFP Side by Side...
A loud vibrating sound
Bad compressor, if the compressor is going bad or the bolts that hold the compressor in place are loose. Check to make sure the bolts are tight. If not check the compressor with your hand and see how much it vibrates.
Jan 02, 2010 | Kenmore 53642 / 53644 Side by Side...
Loud vibration
If it is a frost free check the fan inside. The fans can have bearing failure after a few years thus causing the vibration. Also the compressor underneath is mounted on rubber vibration dampers and if one of these rubber mounts fail then the compressor will start vibrating against the refrigerator frame causing a loud vibration. If none of these apply gently press on the side and front panel of the refrigerator to try and locate the source of the vibration as any where metal is vibrating against metal the side and front panel act as a sounding board amplifying the sound. If you cant locate the vibration then you may have a more serious problem and may need to call a technician.
Oct 09, 2009 | Roper Refrigerators
Loud vibrating sound with compressor starts up
remove the back cover and visually inspect the small fan under the fridge, chances are the fan or blade has become unbalanced or the mount has come loose or failed.
Jul 12, 2009 | GE Refrigerators
Hotpoint tuble dryer, Aquarius, VTD20 makes scraping sound
sounds like the back drum shaft has worn and dropped through back[plate ... there is a fix for this by buying a new drum shaft and support kit comes with front bearing also .. can be a tricky job tho ....
Mar 30, 2009 | Hotpoint NWXR473EV Dryer
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fridge makes loud moaning sound
It is the control board. There is a recall on certain models and serial #'s that will cover the parts, but not all are covered. do a google search for hotpoint or GE howling noise. you will find out all the info you need.
Mar 14, 2008 | Refrigerators
Loud grinding noice before starting to print
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
Jan 25, 2008 | HP PSC 1210 All-In-One InkJet Printer
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
