When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are just visible under the Magenta. If I use "Plain Paper" the photo prints true to colour. I've tried this on 2 different computers with different printers (HP and Canon) and get the same results. The photos were tweaked a bit in Picassa/Elements on my Sony Viao. HELP! Please! John Pelham
    Master:
  • 377 Answers
In addition's for; smilemaker, otacon, early1234 solution/s.
Several common factors that will affect the colors in your printed image or photo.
Start by checking your paper. Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color.
Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors.
For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow.
Check your ink cartridges and replace any that are low or exhausted.
/eop
Posted on Mar 25, 2008
  • pincer
    pincer Mar 25, 2008
    If you make the prints at home, these factors include the kind of printer you use and, in the case of an inkjet printer, the types of paper and ink you use. You may also need to make some adjustments to your printer’s settings.
  • pincer
    pincer Mar 25, 2008
    About PRINTER; there are three kinds of printers capable of producing photos:
    In the inkjet printing process, the printer sprays droplets of ink onto the paper through a print head that contains hundreds or thousands of tiny nozzles. The more nozzles there are on the print head, the more consistently the ink will be spread on the paper, and the faster the printing process will be completed. Each droplet can contain only one color. However, some inkjet printers can lay multiple droplets of different colors, one on top of another. The final photo comprises thousands of tiny contiguous dots formed by the ink droplets.
    Dye-sub/thermal dye-transfer printers do not use ink at all. In these printers, the print head heats a polyester film that has been infused with cyan, magenta, and yellow dyes to transfer the dyes one color at a time to special photo paper, which has been matched to the printer. The layers of color combine to form the photo image. The result is what experts call a "continuous-tone" image, which, upon close inspection under a magnifying glass, appears to be one uninterrupted plane of color. In this way, a dye-sublimation or thermal dye-transfer print is like a photo made from film. Both film photo finishing and dye-sub printers create continuous-tone images, although the dye-sublimation printing process is technically very different from the process for developing and printing photos from film.
    Color laser printers are a third option, although they are primarily designed to print text and business graphics, not photos. Also, laser printers cost more than the inkjet or dye-sub/thermal dye-transfer alternatives.
  • 871 Answers
When printing, select plain for softer colors. for glossy ...heavy colors.
as smilemaker said. it will be longer in glossy paper.
    President:
  • 1,944 Answers
What paper are you using now? And which printer models are you using?
  • 790 Answers
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
I have a Epson pro large format 9600, I print on canvas, I have use Photo black since I have it, but never getting a saturation ressult. I have been counsil by Epson to use Matt black rather than Phot
"Photo black" is designed specifically for glossy photo paper. Matte black is for non-glossy paper, including plain paper. Matte black will print darker on non-glossy paper than photo black does.
Oct 28, 2014 | Epson Office Equipment & Supplies
Wet smudgy lines on printing 6x4" photos, on glossy kodak photo paper. Ok bon plain paper
Before you hit the [Print] button, click on the [Properties] button. Then you have to find the setting where you select various types of paper. Select Glossy Photopaper and see if that helps.
Mar 01, 2011 | Office Equipment & Supplies
My R1900 is over 1 year old. Profiles are set for Epson glossy and matte paper. Epson ink is used. Colors are now very green when printing to glossy or matte paper. However, if I use the plain paper...
The difference in choosing the paper type will have an impact on how head squirts ink onto the media. For Epson printers, the best choice to fit the color is plain paper.However, to the maximum dpi (best photo or photo rpm), plain paper does not support.This can be overcome by adjusting the color management of the program that we use.Or convert to bitmap all objects (such as Corel Draw), or also in print as bitmap option.
Feb 22, 2011 | Epson Stylus Photo R1900 InkJet Printer
The printer prints fine on plain paper, but on
I'm not clear on your problem but you can try this<a href="http://www.richardsnotes.org/archives/2006/05/17/canon-i9900-printer-problem-and-solution/" >Link for simular problems.</a> You may find the solution there.
Nov 27, 2009 | Canon i9900 InkJet Photo Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Printing Problem
my laptop sony vaio vgn-n130g it is do not work LCD back light in press (Fn and F5- F6+)
Mar 25, 2008 | Sony VAIO VGN-N130G/W Notebook
Printing Problem
You may have a problem with your magenta color cartridge ????
Mar 25, 2008 | Office Equipment & Supplies
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
