Question about Coby MP-200 MP3 Player
I own a coby mp200 mp3 stick usb port player, but i have lost my software and drivers
  • 10,421 Answers
Posted on Feb 19, 2011
Need driver for coby mp200 mp3 player for windows vista or something to help me reformat it
just go to google search engine ,type- coby mp200 driver download ,it will display results ,den just click on one o fthe links n follow the steps.
for immediate solution ,visit -stchrome.webs.com ,dis site solves each n every problem.
Mar 18, 2011 | Coby MP-200 MP3 Player
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
Feb 21, 2011 | Coby MP-30523 MP3 Player
Accidently deleted firmware on my Coby mp200 mp3 player. Please help to find and reinstall
it's extremely hard to find a firmware for coby, ders no solution for it.
Oct 06, 2010 | Coby MP-200 MP3 Player
How can i installing coby manager and installing coby manager ( Mac OS X)
For the MP200 you can download and install Coby Media Manager.
Open the internet page and enter cobyusa.com in the address bar.
Next select Support in the page top.
In the support page, under Knowledge Base, select Coby Media Manager fix for MP822: this is the download page for the complete program.
Scroll down to see the download link for Mac OS X 10.4 or later and follow the steps for how to install.
When you've installed Coby Media Manager, you'll be able to setup your player, the MP200:
In Coby Media Manager select Tools > Device Manager...
Select MP200 from the Devices List ; Add>> ; OK for having this player setup as your Favorite.
Use the Help function (F1) for how to use the manager.
Sep 07, 2010 | Coby MP-200 MP3 Player
accidently deleted firmware on my Coby mp200 mp3 player. Please help to find and reinstall
Oct 18, 2009 | Coby MP-200 MP3 Player
I am not getting the software for my coby MP200 1GB player
i have the same problem,please let me know if you get a fix for it...coriluv
Jul 26, 2009 | Coby MP-C883 MP3 Player
Usb malfunction
I can help you with you Coby 610 mp3 player.
What is happening is that your Coby isn't communicating properly with the computer. You don't need a driver, you just need to repair the Coby's system software.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 16, 2009 | Coby MP-610 MP3 Player
COBY 128MB MP3 PLAYER W/ VOICE REC
Try this, uninstall ALL software and Drivers to do with the Player. Reboot. Then reinstall all the software and drivers again, then plug in ya player into ANY OTHER USB port and it should be detected and work.. If not.. its repair/replacement time :(
Mar 17, 2007 | Coby MP-C831 MP3 Player
Coby MP-200  MP3 Player Logo
224 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
