Question about Danco Faucet Stem
How do i remove the faucet handles?
I have removed the screws on the faucet just am not able to remove then to get to the stem.
  • 349 Answers
They make sockets for stems to break them loose from valve. It should have a place for a wrench to break it loose also.
Posted on May 03, 2010
How do I change the washer on faucet
1. turn off water under sink 1st both of them
2.remove the handle screw on top or allen screw under bottom of handle pry off
3.crescent wrench unscrew valve remove
4.on bottom of stem unscrew remove washer{replace the "O" ring on the stem while out}
5. put back and turn on water check for leaks,
Hope this helps let me know Mike
Jan 03, 2016 | Globe Union Glacier Bay 8 In Double Handle...
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
Replace ceramic disk cartridge
First shut off water to the faucet. Most faucets have a screw on each hot and cold handle, remove the screw, then remove the handle. Now you should see a large Nut around the faucet stem, remove the nut, then the stem can be removed. Depending on the faucet you have, the ceramic disk can be replaced. Most faucet companies give a lifetime warranty on the disk, so you can order a new one for free if you have the warranty papers of the faucet, if not, you can usually get new parts on line, or at a plumbing store.
Nov 23, 2013 | Globe Union Glacier Bay 8 In Double Handle...
How do I replace the spring and rubber seal
First turn water off to faucet and remove the screw that hold's the handle in place. They may have a cap on the handle to remove to access the screw.
After screw is out the handle should come off you may have to wiggle it a little to get it to come loose. Next you will have access to the spring and washer for that stem.
It should be located on the bottom of the stem just remove it and replace new ones back in place.
Some have sping's and seat in the body of the faucet if not located on the bottom of the stem.
Jul 13, 2010 | Delta Faucet 2530CBLHP/H25 Innovations 4''...
Water leaking at handle when turned on
1- Hanldle may have a cap that will come off to access screw to loosen or allen screw on the handle to remove it.
First thing you can check remove handle and make sure the nut that holds stem down is not loose. You can tighten it and try this first just replace handle turn on and check for leaks.
If not please go to step 2 in removal of stem
2- Cut water off and remove handle to gain access to stem. Next remove stem by untighting nut at the base. Remove stem and replace o rings on stem about middle of it. That will stop water from leaking at the base.
May 19, 2010 | Kohler Fort© Widespread Lavatory Faucet...
How to remove diverter cartridge in shower 1 handle
Follow these steps.
  1. Remove Set Screw in handle and remove handle.
  2. Remove the 2 screws from the handle housing and remove the housing and escutcheon from escutcheon adapter plate.
  3. Remove valve stem screw and valve stem coupling.
  4. Remove the escutcheon adapter screws and escutcheon adapter.
  5. Using a pair of pliers pull the cartridge retaining clip out of the valve.
  6. Grasp the cartridge by the stem and pull out.
I hope this is helpful to you, please rate if this answer was of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Moen & One Handle Tub & Shower Faucet
Kitchen taps drip and leak.I do not want to replace with new but would like to sort these problems.
dependent on the type of faucet, you need to replace (a) the washers, (b.) the spring and seals or (c.) the gasket. They all serve the same purpose. 1. turn off the water supply to the faucet. 2. double handle? (a)remove the center cap (b) then remove the screw holding the handle down (c)next unscrew the valve stem retaining nut (normally it is the one right above the faucet body). (d) pull the valve stem out, if there is a small rubber piece held down by screw remove the screw, replace the washer. if there is a rubber gasket wrapped around the stem, remove and replace it, if nothing is on the stem look into the faucet body you should see 1 or 2 small rubber pieces these are the seals the springs are right below the seals. Remove and replace springs and seals. 3. single handle? remove the handle retaining screw, normally covered by hot/cold indicator symbol, unscrew valve stem retaining nut, pull the valve stem and replace either the gasket or springs and seals.
Aug 28, 2009 | Home
I have a Sgl Lever Kit. Sink Fct. model 63500. I changed the seats & springs. When putting the handle back on the ball stem and tightening the set screw the handle will not come off but spins to the...
the set screw in the handle is not tight enough. I suggest you remove handle, remove set scew, clean and lube set screw, re install screw and fully run in and out several times. THEN out it back on the faucet ball stem.
Jun 03, 2009 | Plumbing
Kitchen sink keeps dripping...how and what do I need to do to stop the dripping
Is this a single handle faucet or a double handle? If it's a single handle, you have to turn the water off then remove the handle. The set screw for this should be under a little plastic plug under the handle near the base of the handle. After you remove the handle, remove the housing cap to expose the valve ball. Under the valve ball are 2 small circular washers and springs. Pull them out and replace them. If it is a cartridge style faucet like a Moen, then you remove the u shaped retaining ring and pull the cartridge out.
If it is a double handle faucet, remove the handle and using a pair of pliers or a crestent wrench remove the stem. You will find the washer at the base of the stem held on by a screw. It could also be a washerless stem and in that case you will need to replace the whole stem.
If you have anymore questions, just respond to the post and I will get back to you as soon as I can.
Mar 22, 2009 | American Standard Plumbing
Danco Faucet Stem  Logo
191 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
