Question about ElectroVoice http://www.electrovoice.com/products/70.html Amplifier
Where can I send ev power amp for repairs - ElectroVoice http://www.electrovoice.com/products/70.html Amplifier
What inline fuse should be used for 12V power supply from vessel to EV-200 ?
First, type-1 is not an hydraulic system. It's electro-mecanic.
The EV-200 needs 2 power supplies. 1 for the calculation unit ( thru the Seatalk OR by a connection in the ACU ) AND a feed for the pilot motor/pump.
The calculator power ( NMEA ) needs only a 5 amp fuse. The 'high' power needs an eventual 25amp fuse. In fact, the power output to the motor is totally protected from overloads and/or shorts. Have those cables between power distribution and ACU thick enough to handle 20amps on his length ( twice the cable distance between battery and Acu is the lengt to calculate with )
Sep 20, 2017 | Boating
What fuse to be used for power supply from vessel to EV-200 ?
Go by what the manual says. That spec is for the input current , not the output current.
Sep 19, 2017 | Boating
Telex EV SonicXS Computer Speakers Not turning on
Hello harisoza, check for power amps, and fluctuation on that room. or entire home, . sometimes this lead to this kind of problems.
Carl
Jun 21, 2012 | Sonic EV SonicXS 4.1 Computer Speakers
Where can I send my ND967 EV mic to be repaired?
Assuming you live in the US:
Fill out this form and put it in the package with the microphone: http://www.electrovoice.com/sitefiles/downloads/Repair_Info_Form.pdf
Send to:
EV Microphones Service Facility
8601 Cornhusker Hwy
Lincoln, NE 68507, US
Tel: (800) 553-5992
Fax: (402) 467-3279
lincoln.asa@us.bosch.com
Mar 05, 2011 | ElectroVoice ND967 Professional Microphone
Rheem 13PJA42A01 heat Pump,top side freezing how to troubleshoot expanion valve/repair?
expansion valve should make a ticking noise when powered up, if not it will be a faulty ev coil motor or pcb not supplying voltage.
with a set of guages on you will notice the unit will pump itself down if the ev is not operating or there is a blockage.
Dec 20, 2009 | Heating & Cooling
Electro voice ma-1212 shorted 2sd5200 power transistors
Your best bet would be to contact EV. Search for either EV or Telex. Telex will be easier to find and contact the repair department. Ask for the part availability and cost. They are very helpful there. Please let them know the model number as well.
Dan
Apr 16, 2009 | ElectroVoice...
Hooking up sound system
The RSQ player goes into the input section of the mixer.
The mixer effect send goes to the Quadraverb input and the output of the Quadraverb goes back to the effect in on the mixer. Now the Main out on the mixer goes to the EQ then the EQ goes to the compressor/limitor to power amp to speakers.
Apr 02, 2009 | Stanton Sa3 DJ Mixer With Eq System
EV sonic XS 4.1 computer speakers and amp
Hi CarrieBeth
depending on the brand of your speakers (creativelabs) etc, have different models, but some of them have problems with AMP, and subwofers. Send me your brand or model, to help you out more direct, or depending on the brand, some models lile 5600 from CL. have problems on the AMP module on the sub. have to change or fix the AMP chip.
hope I can help
Carl
Nov 16, 2007 | Sonic EV SonicXS 4.1 Computer Speakers
I can not get the phone out of EV mode?
The EV is not a mode of the of the phone, it's a service status, representing the data-transfer rate your phone can handle in your current area. The text message problem is likely not linked to the EV symbol.
Sep 30, 2007 | Motorola Mobility RAZR V3m Cellular Phone
ElectroVoice http://www.electrovoice.com/products/70.html Amplifier Logo
29 people viewed this question
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
