Question about LG WM-0532HW Front Load Washer
My wash machine has a bellows part (4738ER1002A) that is leaking and I took it out. Sure enough it has a tiny hole in one of those accordeon style grooves. If I use silicone sealant will it hold up (at least until I get a new part)? Or is the detergent and hot water going to melt it away?
  • fxyspm2 May 02, 2010
    Well, I tried silicone but it does not adhere to rubber. I will have to go search for something waterproof that adheres to rubber.
I have the same LG washer, with the same drain "bellows" and the part has failed exactly the same way 4 times over about 4-5 years. It is a POOR design. I have tried to give feedback to LG but they are not interested in customer feedback.
Posted on Dec 30, 2010
  • LG Master
  • 12,061 Answers
Ok, well as long as you get a "Glue" that actually "Melts" into, the existing material, much like a water bed glue/sealer, you will be OK, for a bit. IF you can get inside, then do the repair inside that way the water is pressing it harder against the wall, Just do a couple of "Layers" with the last, patch, bigger than the one underneath, and glue all round the margins, let set, and do the other layer(s) Use really good solvent waterproof glue...sealer silicone...
Posted on May 02, 2010
Why is maytag front load washing machine is leaking at the bottom of the door
Either the door is out of adjustment or the bellows (the rubber large seal on the front of the machine) has a rip or hole in it . This can happen if you fail to remove all items from clothing before washing. Carefully inspect the bellows for holes or foreign objects remove any objects from the machine and replace the bellows if necessary
Aug 05, 2014 | Maytag Washing Machines
Tiny leak at front of machine
Is this a FRONT LOADER? Or, a TOP LOADER?
The following link explains how to access and inspect the interior of a FRONT LOADER and what common sources of leaks to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
The most common source of front loader leaks comes from the door bellow (gray rubber seal). A routine inspection around the perimeter of the door for rips or tears will tell if the bellow needs replaced. If the bellow requires replacement, the following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If this is a TOP LOADER, the following link explains how to access and inspect the interior for common sources of leaks:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The most common source of leaking on a TOP LOADER is the drain pump. These pumps are not serviceable and if found to be leaking, need to be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Whatever style washer you have, make sure you read through the links provided and follow the steps on how to properly access your washer interior so you can get an accurate view. Make sure you check all tub seals, dispenser hoses and drain hoses as well.
Replacement parts (if required) can be purchased from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jun 22, 2010 | Washing Machines
Leaking water
If your LG washer is a front loading machine, the bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE. this can be hard to detect sometimes but can save you alot of grief. hope this helps
Thanks
Oct 11, 2009 | LG Washing Machines
Front Loading Washing machine door gasget leaking
These arent terribly difficult with mechanical capabilities. The clamp which snugs the bellow to the tub (toward the inside) can be tricky. The front is snugged by a spring loaded cable. Also, take care to align the fill tube at approx. 10 oclock looking at it from the front. And make sure the fill tube is entirely through the hole in the new bellow. It can get frustrating but usually takes less than 30 min.
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Bellow Replacement
Make sure the drain holes are clear in the bottom of the bellow. Also, make sure the bellow is aligned properly. There should have been an alignment arrow at the 12 o'clock position. Hope this helps.
Aug 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44082 Front Load - Door Leak
you did fine several companies built kenmore for sears yours looks like a frigidaire on some models there is a problem with water collecting at the bottom of the door where the bellows or boot is and leak to correct this they came out with a new boot that has a channel at the bottom with three holes in it so the trapped water can drain back into the tub the parts kit for that is 5303937187 now on washers with rubber boots its recommend that you shut the door with a little force to make sure it closes tight against the boot sorry about the letters they came with the part number you might want to call kenmore parts to ask about the boot kit if i was there i could tell you but it looks like a frigidaire to me
Mar 12, 2008 | Kenmore 44072 Front Load Washer
Whirlpool duet water leak
Open your wall faucet to full pressure to stop the drip. If this does not work simply change the inlet valve of the machine which is at the top, where the water enters the machine. You can do it yourself. And rate me plz if helped.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Nov 10, 2007 | Whirlpool GHW9150 Front Load Washer
Machine leaks
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn't drain water from a backed-up standpipe (see HERE for information on clearing clogged drains). NOTE: To prevent serious flood damage that can occur if washing machine supply hoses burst, be sure to install "no-burst" stainless-steel mesh hoses and lever-type shutoff valves, as shown in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days. 1) Check the fittings where hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses and drain them into a bucket after disconnecting them). 2) Determine whether machine is over-sudsing during wash loads-- this can cause the entire washing machine to overflow. Reduce suds by pouring a mixture of 1/2 cup of white vinegar and 1 quart water into the washer. Then switch to less detergent or use a low-sudsing variety. 3) Call a repairperson. The machine may have a faulty basket gasket or tub seal and bearing that must be replaced.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
460 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
