Question about LG WM-2277HW Front Load Washer
Door seal on washer is leaking - LG WM-2277HW Front Load Washer
  • LG Master
  • 8,220 Answers
The guys at LG recommend shimming the latch catch between the latch and frame to make the door close tighter. For true.
Posted on May 02, 2010
SOURCE: Leaking beneath door, Whirlpool duet washer
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Posted on Jul 18, 2008
jsrock516
  • 5911 Answers
SOURCE: front loading washer leaks
The rubber seal (or bellow) wears with age and will eventually deteriorate over time. Excessive use of detergent, and/or use of the wrong detergent (detergent that is not HE) can contribute to rubber breakdown too. Regular detergent is formulated for washers that use a wash tub with a capacity of 35 gallons. HE detergent is formulated for High Efficiency washers that only use 5 to 7 gallons of water. So, if you place regular detergent in an HE washer, you are (in affect) putting a higher concentration of soap in your washer. This higher concentration of soap can act as a corrosive to rubber and become permeated in your clothing as it does not rinse completely. This can lead to skin irritations as well. It is important that if you are not using HE detergent that you do so in the future to prevent premature breakdown of the rubber seals of the washer and pump. This will also void most manufacturer warranties if it determined you are using improper detergent. Now...I'm not trying to accuse you of abusing your appliance and not trying to lecture you. I'm merely putting this information out, because some people simply do not know. Overloading the washer is another contributor to excessive wear on the bellow as well as not keeping the bellow cleaned properly. Mold and mildew can contribute to the break down of rubber. The following link can give some advice on proper care of the door bellow:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
Since your bellow is already leaking, it must be replaced. Replacements can be ordered on line at either searspartsdirect.com, repairclinic.com, or pcappliancerepair.com. All these websites offer competitive pricing, so you can shop for the best deals. Just type in your COMPLETE model number to begin your search. The Sears website offers helpful exploded view diagrams to assist in part identification and location. NOTE: You may consider ordering the front and rear bellow clamps if yours are damaged. Refer to the Sears website for pictorial view.
If you need assistance in replacing the bellow, the following link will give you the steps necessary to complete this repair on your own:
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 24, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Posted on Feb 16, 2009
SOURCE: torn door seal on front loading washer
My husband used super glue on the tear and for now the washer is not leaking.
Posted on Mar 26, 2009
  • 41 Answers
SOURCE: HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Posted on Sep 03, 2009
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
My whirlpool duet sport washer is leaking in the front underneath, not from the door. Does not do it when it drains. What do I do?
Hello Casey,
Its possible that the washer could be leaking from the door seal yet ya don't see it coming from the door. The way to check if its the door seal remove the lower panel and see if the concrete counterweight that's on the front of the drum...if ya see water dripping from that counterweight,its from the door seal.
If the door seal is not leaking ya would need to look at the pump and hoses on the tub while it was in wash mode to see whats leaking.
GENE
Oct 11, 2011 | Whirlpool GHW9400 Duet Washer
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When i run the washer there is a small water leak coming from the front of the door.
sounds like u have your front door seal leaking make sure theres not any trash in the seal or around the door if not u might have to replace the seal
Feb 26, 2010 | LG WM-2277HW Front Load Washer
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Torn door seal on front loading washer
Mar 25, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore dish washer leaks thru the door, need replacement seal.
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Jan 26, 2009 | Dishwashers
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer Leaking
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process of how to fit and replace
Sep 30, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
LG WM-2277HW Front Load Washer Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
