Question about HP Compaq Presario SR2023WM PC Desktop
Hp sr2023wm core just shuts down. boot back and shuts down again! runs for hrs and then poof down again. possibly a power suppy? or an overheating processor?
  • 666 Answers
It most likely an overheating processor, remove heat sink assembly and clean up including fan, return back and put some silicon paste on top of the processor. let on and observe. check also for board capacitor if no sign of burn.
Posted on May 02, 2010
  • 5,603 Answers
If you are overclocking the processor it may be overheating.
ALSO check that the fans are running, including the one on the processor AND vents and heatsink fins are not clogged with dust.
Also consider if your pwer to the unit MIGHT be glitching or brownout due to heavy loads or bad receptacles or wiring. Make sure you are not running off a switched wall receptacle.
  • OSU-Buckeye Feb 22, 2011
    I just had this same problem and it was not an over-temperature CPU. It behaves just like it, but can shut down very quickly after power-up. Sometimes it's hard or almost impossible to boot because it shuts down before it can even complete a boot. Hopefully this will help other people. Here's what it was...
    My problem was the motherboard (MB). My system would power down just like a thermal problem, but that's not what it was. I think many systems will now start failing like this because the problem was caused by internal temperatures. The high temperatures over time damaged a group of capacitors (caps) near the CPU socket. All of the caps that failed were of the same brand. Other caps in the same vicinity from another manufacturer did not fail. If you know how to solder and own a high temperature soldering pencil with a very small tip you can do this repair yourself. Otherwise, you can replace the whole MB. It's easy to do. Your replacement will come without the CPU so you will have to take yours out and put it in the new MB. You will need to remove the heatsink to do this, and it's best you order some thermal paste when you do this job. The HP system number of this computer is RE747AAR-ABA. If you search for this you will find that replacement MBs have the number:
    A8M2N-LA NAOS GL6 (Asus number)
    RB043-69001 (HP number)
    Now, back to the capacitors... There are 6 electrolytic capacitors next to the CPU socket towards the back of the computer. You can spot the bad ones because they will have swelled. Some may eject carbon-like grime either from the top or at the bottom. All of the ones that were bad on my MB were brown and had a KZG marking. These are 1800uF 6.3V capacitors. I think they are Chemi-Con parts, but I'm not sure. There are many posts on the web claiming there was a bad batch of caps that got out. Looks like HP got them. I had one more cap that went bad, it too was brown with same marking but was a 1000uF 16V capacitor. None of the black (dark blue) caps went bad. There are more brown caps on my MB and they will probably go bad eventually too. I'll be ready for them.
    Good luck.
    (Posted by Buckeye)
I have a presario sr2023 that will turn on all fans and other components seems to be working. I just do not get a screen on bootup. When I plug my power cable in the computer will bootup ( no screen)...
The reason why your PC boot up by itself because you didnt shut that down properly the last time you used that. before you turning your PC on,,,, maybe the memory card was not properly detected by your system, remove those memory card/s and clean or wipe the connector area with soft cloth or tissue paper. If your memory card is good and there was no bad hardware installed on your PC?.. There has the big possibility that your PC boot normally up after you clean and properly inserted those memory cards to your Desktop.(test the memory card one by one) Good Luck for best results.
Aug 16, 2014 | HP Compaq Presario SR2023WM PC Desktop
Heater problems 2009 dodge nitro v6.
Possible, with rad cap off, let vehicle idle until coolant fan comes on then shut vehicle off for 30 minute cool down. Top up rad, install cap and drive and recheck heater operation and any overheating.
Jan 03, 2014 | Dodge Nitro Cars & Trucks
HP w/ Vista will not boot.
Try the other keyboard just to be sure.
But it sounds like your board is about to go belly up.
Apr 20, 2012 | HP Compaq Presario SR2023WM PC Desktop
K8N mortheboard no signal screen
HI,
In this new tower you are swttching to, does it have it's own power supply? And if so, what are the amps, and what are the amps on your old power supply? I have the K8N, and it needs at least 450W to run decent. Let me know?
Mark
Jan 03, 2010 | ASUS K8N-DL Motherboard
NAD T747 Shutting Down
get a fan or do a re-stack...open the back of the e-center, Yes it will do a thermal shutdown... just like 3 mile island
Dec 10, 2009 | Audio Players & Recorders
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
PC SHUTS DOWN ON ITS OWN
Could be a few different possibilities-
Power Supply failing
Overheating Issue
Virus-
first thing i would do is to try booting the computer up into safe mode with networking. to do this:
Shut off your computer and turn it back on- immediately start pressing the F8 key repeatidly until you get an advance boot menu- then go to safe mode with networking and press enter on your keyboard- See if Windows operates normally while in safe mode- If so then issue is probably a Virus.
Apr 09, 2009 | HP Computers & Internet
Overheating, battery not charging problems booting up
Sounds like you get a virus. If possible back up your data. Format your hard drive and reload your operating system. Load and run anti-virus. Load data and applications. Run anti-virus again. That will leave you will a clean hard drive.
Jan 06, 2009 | HP Pavilion zd8000 Notebook
Powers off by itself.
Power supply or sweep suppys have parts that are overheating and breaking down or cold solder connections. Call someone who knows this set like the local authorized magnavox/Phillips dealer/servicer. Good Luck
Aug 04, 2006 | Philips 60P8341 60" Rear Projection...
HP Compaq Presario SR2023WM  PC Desktop Logo
133 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
