Question about Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D monoblock
I have a Complete Kenwood system in my car but having problems with Kenwood KAC-9152D 1800 w monoblock - I have 2 x 12" DVC 1500W on it and and if I connect them for 4 ohm DVC set up to 2 ohm amp load. 4 ohm I dont get DVC bass because my old SVC 12" 500 W pumped like mad (On sub NEG to NEG then neg to amp NEG and the POS to POS on sub and then to POS on amp) got it from website 12 Volts. It plays hard and best bass but it kicks out and stays of for a few seconds then comes back and pump for 30 sec and off again. I do have a CAP 1.5 F and 4 gauge from pos and battery and ground also 4 gauge bolted in to body with paint sanded of. One thing I cant understand is how does the amp know when it is 2 ohm or 4 ohms
Posted on Mar 29, 2008
    Sergeant:
  • 300 Answers
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
OR
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Posted on Mar 25, 2008
Kenwood repair manual
I have the Kenwood KAC-9152D Repair Owners Manual. This is my E-Mail address. canalv11@gmail.com send my a e-mail. & I will e-mail back 2 U w/the Manual ATTACHED
Dec 21, 2011 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
I have a kenwood kac-9152d amp i fried it opened it and the inner ground wire was fried in half now it just blows my fuses????
Dang! That's a class D anp! How did you fry it? If you "replaced" the internal ground wire and now it just blows fuses, I would say that the amp is direct shorted at the power supply if the fusesblow instantly when you put the fuses in.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 26, 2008 | Kenwood KAC-9152D Car Audio Amplifier
I need help
Most of the time if the red light is on the amp is no blown but some times it does this cause the subs are hooked up in the wrong way. If the amp is only 2ohm stable and you hook the subs up to it at 1 ohm than the amp will not work so I would check this frist.
Oct 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio amp
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Sep 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac 9152D
Usually, protection mode is caused by one of these conditions:
  • Shorted speaker outputs.
  • Speaker output shorted to ground.
  • There is an internal issue, causing DC voltage to be present on the speaker outputs.
  • Amp overheats.
  • Ground connection is insufficient for amp or HU.
I'm not sure of the history or symptoms of your amp, but those are the reasons why the amp could go into protection mode.
Mar 13, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
Mar 11, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood kac-9152d
by jump do you mean all it does is thump and no sound besides thumping noise? if so put a better ground on your amp, double grounds work the best. please reply
Oct 06, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D Car Audio Amplifier Logo
190 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
