Question about Kodak 5300 All-in-One InkJet Printer
I installed a new black ink cartridge and it doesn't work.
I replaced a black ink cartridge from my printer and printed an image that has a color black and still wouldn't show up after i printed it.
    President:
  • 524 Answers
  1. Open the cover of the Kodak 5300 printer. Take out the cartridges that are to be reset.
    Find the filing hole. It will most probably be somewhere on the bottom or the rear of the ink cartridge.Moisten the syringe's needle and push it into the sponge all the way through the filling hole. Make sure you do not apply too much force, as the sponge will likely rip apart and consequently will cause clogs.
    Keep the ink bottle on a stable surface. The syringe's needle is usually very delicate and thin. Slowly, squeeze the ink bottle to make the ink flow into its sponge. Again, do not apply a lot of pressure or the sponge might expand, which will cause the ink to come out disproportionately during printing.
  2. Squeeze the ink into its sponge until it starts to look moistened. Make sure you do not fill up too much.
  3. Use tissues for wiping the filling hole. Install the refilled ink cartridge on your KodakI installed a new black ink cartridge and it doesn - 2_bing.gif 5300 printer. You will hear a click when the cartridge installs at the right place.
Posted on May 02, 2010
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Printer will not print. New black ink cartridge. Color ink is almost gone. Help.
Printers that execute high quality images cannot (actually will not) allow printing when the other printer cartridges are almost gone or gone. This is a built in defense against the printer heads drying out and much servicing and expense.
You simply do not own a printer of any kind and allow the color cartridges or black cratridges to run out (or even get close) without having th replacement cartridge at hand for immediate installation.
This is how the printer manufacturer protects itself from costly warranty repairs and lawsuits.
Go immediately and buy the color ink cartridge and install it.
Black is the presence of all colors
White is the absence of all color
Your printer must draw in tiny increments from the color certridges to keep the heads functioning when you predominantly use black printed documents.
Science strikes again.
For God's sake, please do NOT leave me 2 thumbs up and trash my rating incrememntally because you aren't happy about this.
Regards,
TheSelkie
Sep 30, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
My black ink will not print. Do I have to have
The larger of the two black cartridges is used for text only printing.
The saller cartridge is used for black in graphic images or pictures.
This saves you color ink . It allows you to put the black ink on the image without making the color inks blend the black ink.
Don
Jan 31, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Kodak 5300 All-in-One InkJet Printer Logo
268 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
