Question about Acer Aspire 2100 (91.AB675.D02) PC Desktop
I can't see anything in my monitor The system is on everything working properly but no display plz help
    Guru:
  • 163 Answers
Remove the CMOS and harddisk connection from the mohterboard and reboot, U will get the display
Posted on May 02, 2010
  • Devendra Verma
    Devendra Verma May 03, 2010
    This is very helpful for me.
    Thanks for your support
    Thanks once again
CPU is running but no diplay in Monitor
CPU is running but monitor is not display. Prevoiusly it was worked suddenly it happened.
Apr 01, 2010 | ASUS P5PE-VM Motherboard
I have Intel P4 with XP as operating system, it has started given a problem, CPU power is on but there is no display in monitor and the monitor light is also green but blinking very fast,plz tell me where...
It sounds to me to be a video card issue. Make sure that the video card is properly inserted into the mother board and that the cable is properly connected. If that fixes you problem it is connectivity.
If that doesn't fix it, (If you have another monitor available) try to hook another monitor up (that you know works) and see if the problem repeats itself. If it does you are probably going to need a new video card. If it doesn't, then either your monitor or it's cable is bad.
I hope that this helps you, if it doesn't edit or re-post your problem with more information to help trace down the issue.
Good Luck
Jul 28, 2009 | Computers & Internet
My computer
Install proper display driver
Jul 07, 2009 | HP w2207 Monitor
My HP 9311 Tx does not give display on its LCD screen
after loading Operating system just press F5 and wait for 2-3 seconds. if display not appear try 1-2 times. it will come. plz replt if ur problem solved
Apr 10, 2009 | HP Pavilion dv9000z Notebook
Display problam
  1. Make sure that the monitor is turned on and has power. Make sure that the display's power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Check that all video cable connections to the computer video port and to the monitor are properly connected.
  3. Examine the pins on the video cable connector to make sure they are not bent or damaged in any way.
  4. Connect a known working display (if you have an extra one available). If you see video after doing so, replace your old display.
  5. Unplug the video cable and then turn on the monitor, check any message is showing in monitor if its shown means ur monitor is ok or else their is a problem in monitor..
  6. turn off the system and check the ram..
  7. Reset the computer...
Jan 28, 2009 | ASUS MB M3A78-EMH HDMI RT Motherboard
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Computers & Internet
Am using compaq presario cq50 the device display doesnt show anything but other than than display screen everything is working.. properly...
Your laptop is probably working with an external display.
Try to change the setting, by pressing the function key (usually on the bottom left of your keyboard) and the Fx key with a monitor (I don't know exactly which key it is but usually is F4 / F5 or F6).
Nov 28, 2008 | Compaq Computers & Internet
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? Monitor will go on for a split second, then screen will go...
they normally turn off like this when they aren't receiving a video signal from the pc (same as when you turn off the pc). make sure that it is connected properly, and that the video output is activated. try disconnecting from the other monitor while its on and connect the problem monitor...if it still isn't working then there may be a problem with the cable or the monitor itself. Try another VGA or DVI cable. Hope this helps
Mar 29, 2008 | Computers & Internet
AOpen Monitor
It seems a magnatic field effect plz change location or any electric equpment far away to monitor. And if this is window problem then install display driver properly.
otherwise your system in virus effect
Mar 01, 2008 | Gateway FPD2275W LCD Monitor
Open Questions:
Acer Aspire 2100 (91.AB675.D02) PC Desktop Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
