Pioneer PRO-200 60" Rear Projection Television Logo
Posted on May 02, 2010
Pioneer Elite Pro-118 rear projection tv
I was watching my tv and it had a yellow line a couple inches wide and the bottom had blue and people on the screen had blue hair.Is the tv on its way out.I also turned the tv off for about an hour or two and the picture seems fine.Is the tv on its way out or is there a cheep fix?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
414
Points
On my pioneer the whole screen turned red i can still see the picture but everything is red.It has happened a couple of times before but it went away.This time it wont,any solutions?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 02, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
540
Points
Ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
2helpful
2answers
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Pioneer Pro 700HD picture distortion
horizontal capacitor parts should be replaced...
Just got a pioneer elite pro 119 from a buddy of
If you don't mind opening the thing, open it up and follow the power lead inside the TV. Somewhere along the line should be a fuse. I'd start there.
Pioneer Elite Pro 710HD Rear-Projection Television
no reset sequence. usually when the protection kicks in without any warning, it's the convergence ICs needing replacement.
Mr Bob
www.imageperfection.com
1helpful
Pioneer elite pro 118
if the tv is more than 10 years old no its not worth replacing the power supply.if its 5 years or newer yes it owuld be worth the money
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
2answers
Pioneer Pro 1009W
Replace conv ICs. This usually does it.
Mr Bob
RCA HDLP50W151 50 in,, got blue line on left part of screen
If you have a DIRECTV - push the reset on the Directv receiver.
JB
1helpful
2answers
Is this Pioneer Elite Pro 118 worth fixing?
You most likely have cold solder connections on the convergence IC's or on the B+ sources for the convergence. The longer you wait to have this simple repair done, the worse this will get and cost you double or maybe even triple of what it will cost now. Good Luck
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
