Question about Whirlpool GD2SHGX Refrigerator
We have the Whirlpool Model # GD5RHAXNB00. The
We have the Whirlpool Model # GD5RHAXNB00. The temperature controls just went blank and the lights on refrigerator side are not working. The freezer side is working fine and the refrigerator side is still cooling. I am looking to see what is wrong and what needs replacing.
SOURCE: Interior level indicator and interior
The failed part on my unit was 2252189, the electric control board. This board is located on the left side of the refrigerator in the back next to the compressor. Its inside a plastic box on the side. That number has changed to a number WHIW10135090 and cost $84 from www.apdepot.com
A previous post listed a part number 2303805 as being the problem. That part number was the replacement number for the control board that is located in the control box inside the refrigerator. That part is NO LONGER AVAILABLE. It has been replaced by part 2255233 which is the entire control box. cost for that part is $161.00 from AP Depot. I purchased this part first and it was found to NOT be the problem.
I would suggest that anyone who has this problem start with the less expensive part 2252189 and them see if you need to spend more.
My unit worked fine with exception the the refigerator side interior lights and the digital display. Compressor and temperatures were fine. Just an FYI on my problem specifics.
Posted on Dec 31, 2008
peyton32034
  • 410 Answers
SOURCE: WHIRLPOOL GS6SHEXNL00 SIDE BY SIDE REFRIGERATOR LIGHT
funny you asked this question i just had this same problem this week at a customers home. you need the electronic control board located in the compressor compartment behind the refrig. it is mounted in the white box on the left hand rear corner. the whirlpool part number is 2304095 and it is around 175.00 i'm not sure who a local part supplier around you would be if all else fails you could get thru sears..
Posted on Jan 07, 2008
  • 27 Answers
SOURCE: WHIRLPOOL CONTROL PANEL
Hi. Your temperature control board display is bad. You may also have a power convertor board located next to the compressor. Normally you would replace the temperature control board first. I have a temperature control board listed on Ebay as item number 250211412492. Good luck, Mack
Posted on Feb 02, 2008
mikedurland
  • 481 Answers
SOURCE: whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 29, 2008
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Refrigerator Crash
Rod; when a run is melted off the board, it is always a result of one or more components on that board shorting out and drawing maximum current that generates enough heat to first lift up the run and then to melt it in two. So if you only repaired the run you still have a problem on that board.
Jan 13, 2012 | Whirlpool Refrigerators
I have a whirlpool electric glass top stove (model # rf364pxpq ). our electricity went out for only a moment, and when it came back on, the control panel is blank and the oven doesnt turn on. the stove top...
I just encountered the same problem. Power surge during storm caused the control panel to go blank. I removed the panel to get the part number. Reinstalled control panel and it started working. Below are the steps 1) Turn off breaker 2) Unplug unit 3) Remove rear panel 4) Unplug all connections to control panel 5) Wait 5-minutes 6) Reconnect all wires in reverse order 7) Install rear panel 8) Plug in unit 9) Switch breaker to on position Control panel came on, set clock and all oven functions worked.
Jan 02, 2011 | Whirlpool Kitchen Ranges
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Freezer works fine fridge won't cool below 43deg
COULD BE EVAPORATOR FAN MOTOR. WHEN FREEZER DOOR IS OPEN CAN YOU HEAR A FAN RUNNING NEAR THE BACK WALL OF FREEZER SECTION?
Jan 29, 2009 | GE PDS22SIS Bottom Freezer Refrigerator
Whirlpool GW395LEPQ console is completely black and E2 and F3 err
If digits on control board does not shows up after resetting power you need a new control board(part# 9760013 $174.20).
sensor for this model(part# 4455636 $89.78)
Dec 02, 2008 | Whirlpool GW395 Gas Kitchen Range
Interior level indicator and interior lights not working on Whirlpool GD5RHAXNB00 Refrigerator.
Oct 25, 2008 | Whirlpool GS5SHAXN Side by Side...
Neither oven will come on
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Oct 20, 2008 | Whirlpool RBD305PD Electric Double Oven
Whirlpool gold refridgerator light not working and is making funny noise
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD2SHGX Refrigerator Logo
195 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
