Question about Frigidaire Dryers
Its not heating fer231as2 is the model number we cant loctae the fuses
  • Frigidaire Master
  • 8,220 Answers
Probably a bad heating element. Unplug it. Pop the topits not heating fer231as2 is the model number - 075fa34.jpg
Remove the front, disconnect the belt and get the drum out.
Frigidaire Repair Photos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 02, 2010
Model ogf41101 fuse blown cant read the number all works but dont heat the fuse goes to the high voltage need size of fuse
From user abu_abdillah351 has mentiond this before
the problem is the high voltage fuse, incapsulated between the transfo and the magnetron. This supports up to 5000V and usually rated something like 0.65A/0.7A/0.8A and even 1A.
When you open the capsule, you'll see it sitting there between its two connectors
Aug 29, 2014 | Microwave Ovens
Tip
Question about fuse
i have a 2003 ford zx2.the cigarrette lighter does work.i looked at the duse box to see where it is located and its not there.everything is listed except for the cigarette lighter which is why i cant loctae where that fuse is.
can you tell me how to locate the ciggarette lighter fuse since it isnt locate on the panel box like the rest of the items.i checked my owners manual and it talks about the ciggarette lighter and the fuse number which is 20A but it doesnt show where it is located.
on May 29, 2008 | 2003 Ford ZX2
Cant find transmission dipstick on my 1996 240 sx? Where is it loctaed and how do I check it?
Google the year make for the owner manual which will have a diagram showing its location and instructions for checking the level---usually at rear of motor towards firewall(back of engine compartment).
Nov 02, 2012 | Cars & Trucks
Dryer will not heat, the heat element does not get red.
Check if its getting 120v to ignitor if not check the thermal fuse on back of unit. I cant really give much more without model number or brand. hope this helps...
Jun 06, 2011 | Dryers
How to replace the heating element
your problem could be in the heating element.
if it heats but takes along time then check your venting.
if no heat then it oculd be the element, thermostats, possibly thermal fuse..
the sides and back are one piece, so u will have to go through the front by removing the front assembly . you can go to sears.com and go to the parts and service far upper right and parts section, and enter your model number to get a breakdown on this model and get part numbers...I would check those parts with a meter first for continutiy before buying that heating element as most people cant take returns on electrical parts,, hope this helps
Feb 06, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Where is the fuse box for a 1987 4runner? looking for the one for the horn.
Major ones are under the Hood loctaed on the side the battery is on...if I recall correctly.
Jan 26, 2010 | 1987 Toyota 4Runner
Had new element but still no heat
First, you must test to make sure you have full 240 volts to the dryer across the two outside terminals where the cord connects onto the dryer. If you only are getting 120, the dryer motor may run fine, but you will not get any heating. If getting 240, list your model number so we can tell you where that thermal fuse might be on your machine.
Nov 09, 2008 | Dryers
NOT BLOWING WARM AIR
Most dryers have a thermal cutout, a non-resettable overheat protection, take the model and manufacturer details to your local repair store and you can buy one easily.
then its, take off the rear plate, and trace the exhaust air ducts back till you find an identical item screwed to a duct, unplug its connectors screw the new one in place, plug in the connectors.
Exact info cant be given as you did not tell what make and model the affected dryer is
May 18, 2008 | Dryers
Dryers Logo
266 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
