Question about Vacuums
What needle and thread would you use for sewing marine vinyl when using a pfaff 130
  • 2,335 Answers
I have heard Pfaff 140 needle with V-92 or V-138 thread is the way to go with marine vinyl.
I hope that helps.
Posted on May 02, 2010
How do i fix my tension,bunches up the thread
sounds like a blunt needle,or tension at wrong setting.replace needle first.adrian,,,,
Feb 12, 2015 | Singer 8763 Curvy Computerized Sewing...
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
Thread jamming on Viking 5710 sewing machine
Check to see if the bobbin is wound in the right direction. Check to see if the bobbin case area is free of lint and debris. Has it been a while since you last used it? Check to make sure it is threaded correctly by following the arrows if this is a newer sewing machine. Last. Thread direction through the needle can be wrong. Vikings usually thread front to back. If you recently changed a broken needle, it could have been replaced in the wrong direction. make sure the flat edge of the needle is fed into the corrosponding flat area inside the needle case. I hope this helps you!
Sep 05, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I have needles snapping and bobbin tangle
Try to repair in this order.
1) Your machine likely needs oil. Especially put a few drops of oil on the outside edge of your bobbin holder.
2) Try replacing your needle if you have some spares. If you are using a decorative thread (metalized) use a needle with a teflon lining on the eye (called metallic thread needle).
3) Try buying a better quality thread. Do not use generic thread in a sewing machine (i.e. "made in cheap country" with no brand name)
Please rate me..
May 04, 2011 | Vacuums
I cant seem to find a manual or even a threading diagram I am disabled so $$ is very hard to come by I was given the pfaff 130 machine just no manual please help. Thank you Karen V
I searched the web but only found stuff for sale and the Pfaff web site di not show any link to manuals. You might try joining this group on Yahoo. I'm not a member so I can't say this group will have a manual but since they are devoted to the old Pfaff sewing machines they may have it. I think you may find a lot of support at the very least. http://groups.yahoo.com/group/oldpfaffpforum/
hope this helped
Feb 04, 2011 | Vacuums
Where to download free instructions manual for a pfaff 130 sewing machine
http://us.peeplo.com/search/?q=free%20manuals&type=web&from=adg2
May 02, 2010 | Vacuums
Sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Jan 05, 2009 | Vacuums
Vacuums Logo
202 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
