Question about Dryers
Gas dryer pilot? or electric starter.
My sister just sold me her old Whilpool gas dryer when she got a new one. My problem is I don't know if there is a pilot light or an automatic sparker thing on it.
    President:
  • 949 Answers
If you can send me the model number that is on the front panel just inside the door I can tell you for sure what kind of ignition it has. If it is newer than 20 years old it is most likely a hot surface or glow bar ignition and does not require lighting.
Posted on May 02, 2010
No Heat- Dryer will not dry clothes, the pilot light will light for a few seconds with a glow. I have changed the coils and the thermal fuse. Don't know what else to try.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Dryers
I have a Whirlpool gas dryer, I can see through the hole that the piolet light is not lit. Model #LGR7646EQ3. It is not heating to dry clothes, can I just try & relight the pilot light?
heatman101
Aug 28, 2011 | Whirlpool Dryers
I have a whilpool electric dryer type d433-2406026-fm54 this dryer doesn,t heat anymore but the dryer still runs.
heatman101,,.';'
Aug 02, 2011 | Dryers
Dryer will not heat
My guess is you probably got some lint on the ignitor and cause a burnout or a limit to trip. If you don't hear the clicking associated with the ignitor heating up and the flame sensor kicking it off then I would check to see if maybe a limit was tripped. On gas dryers when the limit trips the dryer will operate but simply will not heat up. I have a full page with service manual included HERE
Jul 12, 2010 | Frigidaire GLGR331A Gas Dryer
Pilot light goes out about 2 minutes after starting dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Whirlpool LER4634J Electric Dryer
How do you light a pilot light for my GE gas dryer? Model = DDG7188PHLWH
How old is your dryer? Only models from the 1980's and older have actual pilot flame lighters. If it's newer it will have either a spark igniter or an electric glow bar. If you have a large front access panel across the bottom, then you may have a pilot light. Remove the panel and look for the gas valve. (NOTE: Before lighting anything, make sure you do not smell gas. If you do, you'll need to air the room out before trying) There will be a burner coming out the back of the gas valve control and this control will have a red push button in the front or side of it to allow gas to the pilot only. Using a extended bbq type lighter, light the pilot at the pilot assembly and hold the button for about 60 seconds. The pilot assembly is connected to the gas valve control by a small diameter aluminum tubing with a copper thermocouple right next to it. Release and make sure the pilot stays lit. Before putting the access panel back on, turn on the dryer and watch for the burner to light. It should be a strong blue flame. Let us know if we can help you further. Not knowing why your pilot went out in the first place, there may be a unforeseen issue that may need attention. If you have a propane gas dryer and you ran out of gas, then it may take a while to get gas to the pilot, so be patient when trying to light it. Never hold the button down without the lighter lit at the pilot assembly, so there is not a build-up of gas. If you are not comfortable doing this, I recommend you call your gas co to light it for you, as many will do it for free! Good luck and be careful!
May 20, 2010 | GE Dryers
Gas dryer
If you have a gas dryer2_bing.gif..
If your dryer is electric..
heatman101
Apr 17, 2010 | Whirlpool LGQ8000JQ Gas Dryer
Pilot working but will not dry completely.
Check the burner vents--both intake and outlet for lint plugging. With the pilot working, it is supposed to heat a thermocouple which generates electricity that opens the main gas valve.
Aug 21, 2009 | Kenmore 74602 Gas Dryer
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
Gas dryer
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Jan 24, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
