Monitor compatibility with Windows 7 Home Premium`
I have recently installed windows 7 home premium on my pc. After doing so the tv that I was using a monitor no longer displays properly. I tried installing the most updated driver and did not get any results. I also made sure all window updates were installed...still nothing. I also trying completing a windows repair install. Still no results. The TV brand is a "ilo". Please help!! Thanx... =)
  • 600 Answers
Did you try to adjust/change setting in CONTROL PANEL?
Posted on May 02, 2010
Why has my screen gone black and dark red? Icannot see the tv properly.
Am also having that problem... once you find the solution, inform me too at sure.tsmcp@gmail.com plzzzzzz...... but i have sony vaio i5, 4gb RAM, 500GB hard disk... windows 7 home premium
Jul 16, 2013 | Acer Aspire Z5763 All-In-One 3D Desktop Pc...
WINDOWS 7 HOME PREMIUM ISSUES WITH SEE2-UV150 TRITTON
HOW CAN YOU TRY ANYTHING IF THE ECLIPSE DOES NOT SEE YOUR MONITOR
Mar 04, 2012 | Mad Catz Tritton SEE2 UV150 External VGA...
I could not upgrade neither windows XP, Windows 7 of this Product Model: GT5662. Would you assits? Thanks.
Hello kelvinvu, according to the information that I gathered from this computer model, it has Windows Vista 32 bit home premium installed on it. Windows XP is an older operating system so you can't "upgrade" to it. You could however install a fresh copy (more likely completely erasing all your previous information on vista and data files) or you could upgrade to Windows 7. Since you are using "Windows Vista 32 bit home premium", you have to upgrade to "Windows 7 32 bit home premium" or better. So if you were trying to "upgrade" to Windows 7 Home Basic, it will not allow that since it considers that a downgrade in the Operating System. You should actually be able to pop in the Windows 7 Home Premium CD while vista is running and start the upgrade process pretty painlessly that way. Just access the CD and walk through the menus for upgrading Vista to Windows 7. As a reminder, you must use the 32 bit discs. If you try and use the 64 bit discs (a different operating system as far as windows is concerned) you will have to go through the same process of installing a new version of windows (not upgrade). I hope this has solved your specific problem kelvinvu, have a great day!
May 15, 2011 | Gateway GT5662 Desktop PC
My name is Dr. Ananda Weliwita, I have a Panasonic videocam SDR-H80. When I try to install the software in windows 7 Home Premium 6.1. I get an error that it is not compatible and does not install. Would...
It just means that your videocam is not compatible with windows 7 Home Premium. maybe you can change your OS that you are using that is suitable for your videocam
Apr 30, 2011 | Computers & Internet
Require driver for windows 7 64bit please
I have run into this issue a couple times recently with this exact model & a handfull of other various Monitor's , http://www.filefactory.com/file/cbc1b15/n/ADIMonitorV97.zip , here is a link to the drivers I used on Windows 7 64 bit Home Premium , I installed using compatibility mode ( right click the .exe , select properties from the drop down menu , select the compatibility tab , select run in " windows xp sp2 " mode & check the box at the bottom " run as administrator " . Also you might want to disable " UAC " ( open the control panel , select users , select change UAC settings , drag the slider all the way down to disable , then click apply & reboot your pc for it to take effect .
Apr 17, 2011 | ADI Corporation ProVista M700 (White) 17"...
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
It is taking about 30 minutes, no joke, to print one page. There are long delays and then it seems to do a line and then another delay. This just started today which is a surprise as the printer has been...
Try HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP DeskJet F380 All-In-One Printer
I'm using vista home premium os, however the problem I enccounter is once you install software which is compatible for windows NT, xp home and windows 2000, the software the one I installed is not properly...
Yes, if you use a Virtual Machine, you can install the version of windows you wish to work with, install the software, and it should work just fine.
You will however need a genuine copy of windows to install in the virtual machine.
You may be able to find an image of the OS you need, or a snapshot of an OS, to load into the VM, it all depends on the type of VM you are going to use
Sep 30, 2010 | Microsoft Windows Vista Home Premium with...
Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Microsoft Office 2007 Basic for PC
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
