Question about Logitech Z-5500 Computer Speakers
The control pod says NO DIGITIAL DATA, and no sound comes from the speakers after unplugging the headphones
  • 186 Answers
If your system is anolog or digital i uses usb other connoct it autio digital is a usb connection
Posted on May 02, 2010
Change main fuse but still not working right
First of all, nothing wrong with the fuse. A fuse is nothing but a short piece of wire with a resistance value. If the unit turns on, fuse is fine. The fact that the headphones you plugged in are working tells you that the music is finding it's way up to that point. You must realize that the speakers themselves have additional circuitry that the headphones don't use. If you could obtain a diagram for the circuitry you might find that a capacitor or a diode or a transistor got "zapped" when the high voltage was applied.
If you have this diagram and you don't know what component is defective, can you post that diagram and I would be glad to help!
Mar 02, 2014 | Bose Audio Players & Recorders
No sound without headphones? lg dp173g dvd
Open the Control Panel , select Sounds, choose the speakers, Apply. Unplug the headphones and reboot.
May 12, 2013 | Computers & Internet
Logitech speakers Z506 no sound after unplugging headphones
all i know is try to powercycle if that doesnt work plug headphones in and take back out it kight just work
Feb 18, 2013 | Logitech Z506 Surround Sound Speakers
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
I can only get output sound on my headphone jack not from my speaker out put
Depending on the MP3 brand, if it is an I Pod, the speaker output should be eigther way the headphone jack or the same electric charge outlet, if it is not working as electric charge shouldnt eighter with sound, try blowing the harder you can against the speaker out, do it couple of times, that may work, otherwise some one tried unpluged the sound by twisting instead of pulling out
Feb 06, 2011 | Audio Players & Recorders
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
No power on
Perhaps your ac adapter has failed or the built in amplifier, if it was bought new or not make sure that u have the correct power supply and if your not sure you do find an adequet replacement w/ matching output specs and polarity. They are not expensive or hard to come by. If that doesnt do it than it is more than likely the built in amp located in the sub. Another way to test the speakers is to unplug them from your computer and plug the same jack into a i-pod or any portable audio devices line out or headphone jack if the speakers make sound with volume there may be a problem w/ your computer or config.
Nov 01, 2007 | Logitech X-530 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
192 people viewed this question
Top Logitech Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
JP Services
JP Services
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
