Question about Cobra 29 LTD CB Radio
Will a bad ground affect how far you can talk and recieve
    Champion:
  • 219 Answers
Yes a bad ground on the radio side and antenna side will affect the how well you hear and transmitt.One thing you can do if its on the antenna side is grab it at the bottom around the mount....do you hear better,do you have better noise.
Posted on May 04, 2010
Why does my 91 ford econoline over heat when I turn my heat on?
I've been working a similar issue with a friends truck. When the heater blower motor is off the engine temperature gauge reads normal in the middle. But when you turn the blower motor on the gauge goes way up to the top. The engine isn't really overheating. There is an electrical problem that when you turn the blower on it is affecting the temperature gauge and making it go all the way up off-scale. So far we've found that the blower motor speed control resistor is bad. We replaced that and the speed control works now, except for the low speed setting. I suspect there is a bad ground somewhere and the bottom end of the resistor element isn't grounded anymore. As such too much current is going through the ground in the dash, which is affecting the gauge.
Feb 06, 2012 | 1991 Ford Econoline
Radio comes on will not talk or recieve
Is the meter moving on key up or another radio transmiting to it?
Switch for S/RF, CAL, SWR.........set to S/RFRF gain knob full clockwiseSquelch counter clockwise
If just audio is missing my be Audio Chip i think IC3Bad Crystal or solder to it.May be bad PLL chip any of these 3 could affect both TX and RXI do not suspect mic as there would still be audio just at low volume on receive.
Oct 03, 2011 | Cobra 29 LTD CB Radio
Shock from cooker
Yes, if you are talking about the ground wire, or earth as you put it. If it is not grounded correctly it could cause a shock...Please give good ratings, they mare important to us...
Aug 01, 2009 | Kitchen Appliances - Others
Rushing sound (noise) galaxy 88 HL
RUSHING SOUND ?
1. Get the noise then disconnect the coax and see if noise goes away on receive, if noise goes away then address the ground on your antenna,
if noise still there then address the ground wire from power source
Mar 30, 2009 | Galaxy Radios DX- 88HL Base CB Radio
Can not transmit
You'd be suprised how much a bad mic can affect your radio. Start by trying a friends 4-pin mic, or grab a cheapo one and try it. If its not the mic, then its time for some SWR tuning, the manual tells you how to do that. Its a very simple process to do, and once you learn the steps you'll go right through it like you've been doing it forever. If your mic is good, First I'd check my coax for any kinks or breakage. Problem is a lot of times you may have a bad coax and there isn't even a kink or bend anywhere, I've seen brand new ones that were bad. Then the ground where the antenna is mounted. Can you tell me if your using a mag mount antenna or a bracket?
Feb 28, 2009 | Uniden Bearcat Pro PC78LTW 40-Channels...
Chat room?
As far as I know you should not be able to but I honestly dont know if there is some freeware out there that will let you do this. Good luck.
Sep 29, 2008 | Logitech (980240-0403) Microphone
Swr
Do you have an SWR meter? Are you sure that the connector that screws onto the radio is soldered properly? If the ground is touching the center wire then it will hear but not transmit very far.
May 03, 2008 | Radio Communications
Galaxy DX959 CB radio reception and broadcast
You Need to check and set you SWR on the antenna system. You may also have a bad coax or the ant studs ( mounting hardward ) for the antennas may be bad. It definally sounds like an ant/coax problem Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 08, 2007 | Cobra 18 WX ST II 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
183 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
