Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Samsung washing machine
I am looking for a new filter for my samsung washing machine P1253. No one seems to stock this. Do you know anyone who does?? Even Samsung do not have it! Thank you.
  • 552 Answers
Http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine
Go here for a new filter. If the link does not work, go to the repairclinic website first.
Posted on Mar 25, 2008
SOURCE:
User manual says to check "magic filter" on my samsung wa48j7700aw/a2 if I have stains on clothes that were not there when they went in wash. Where is magic filter located?
For the Samsung washers with the magic filter lint trap, look in the washer tub for this filter. It should be a vertical section on one part of the tub wall in the lowest third of the tub. For an idea of the location and how to open the magic filter, see https://www.samsung.com/au/support/home-appliances/what-is-the-function-of-magic-filter-in-a-samsung-washing-machine/ .
I hope this helps.
Oct 12, 2018 | Samsung Washing Machines
Hi,i have a samsung washing machine,p1253.model and i keep getting a code UE,and it appears not to be spinning.....please advise what this code means and is it possible to read an instruction manual on...
Hi, UE error means unbalanced load, loosen the washing and try again, if the load is to heavy take out some of the washing and spin in 2 lighter loads.
UE Happens if you overload the washing machine.
CLICK HERE for the user manual.
Hope this helps.
(Dont forget the thumbs up if this helped)
Feb 12, 2011 | Samsung Washing Machines
Will not go into spin display reads 5e(model no p1253) ive cleaned debris filter and cheaked waste hose
sounds like you have a faulty pump as its not pumping out as quick as it shold be ...so it times out ....or you have a faulty pcb assy £££££ try a pump first you can pick them up cheapish...9512835
Dec 30, 2009 | Samsung Washing Machines
Letters UE on display
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 26, 2009 | Washing Machines
Samsung p1253 hole in outter drum,what is it made of and is this a common fault?
Hi I take it that the outer drum is made from plastic the only thing that would cause this problem is a large coin got into the drum and as the machine was spining the force made it hit the outer drum and chip it making a hole
Jul 18, 2008 | Samsung Washing Machines
Samsung p1253
LE means locked rotor or overload in motor. Check for binding or mechanical resistance. check motor winding resistance. Also check 3 pin connector in motor harness, harness between stator and main board or Hall Sensor on motor could be defective
Dec 28, 2007 | LG WM-2277HW Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
157 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
