Question about Proview PA15BA7 15 in. LCD Television
I need a new power cord for my PA 15BA7 15" lcd
I lost the power cord that goes to the tv...where do I get another one and how much does it cost
Most TV"s use the same type of power cord that computers use. Here is a link to a site that carries them. You can usually find them in most electronic stores as well.
http://www.showmecables.com/CPU-Power-Cords.html?gclid=CJn1ts77n6oCFQFUgwodsiV25w
Jul 26, 2011 | Proview PA-32JK1A 32 in. LCD Television
PA 21 adapter shows no sign of life. LED does not light up. No output voltage
Try another mains power cord. If this does not work then the PA-21adapter is faulty and needs to be replaced.
Jun 13, 2011 | Dell PA-21 Family AC Adapter For Dell...
What do I need to hook up to our church pa system
Connection all depends on what type PA system you have. Here are the rules: Power this device from the SAME receptacle your mixer is powered by, even if it means running an extension cord. Use ONLY a balanced line from the mixer... either TRS cable or XLR cable.
Apr 02, 2011 | Samson Auro D412A Speaker PA Active
AC adapter, Model PA-1121-08 for Toshiba Satellite A75 laptop PA 3290U-2A2CPA3290E-2A2C Input 100-240V 2.0A Output 19 V, 6.3A Power goes on and off as if there is a short in it, if I bend the...
The correct (political) answer is that your should ALWAYS replace power cords.
Today's computers power supplies have two parts, the wall plug, 3 prong, and the transformer with the "PORT" plug for the laptop.
The 1st part, you can buy new or a qualified technician can splice out the bad part.
The second part, is usually a DC (direct Current) cable with special grounds and insulation. The molding that houses the electrical wires is not accessible to consumers for that very reason. If you have to bend the cable to make the connection, then the plug is clearly defective and SHOULD be replace. In a pinch, depending on how far the break is on the plug, it might too be spliced.
Replace it as soon as possible.
Sep 29, 2010 | Lite On Computers & Internet
I need to buy a longer cord for my PA system system on my shuttle bus...the microphone has the following on it: Executive series 100 CB68A
Mike - it would probably help if you provide the name and model of the PA amplifier too... but even so:
It is doubtful that you'll be able to simply buy an "extension cord" to place between the end of the existing mic cord and the PA's mic jack. You could probably have a new, longer cord to replace the current short cord on your mic fairly easily. Since this would require soldering and use of special sheilded cables, you should probably have it done professionally. Just about any commercial or business radio shop should be able to swap the cord for one as long as you need.
I hope this helps.
Sep 23, 2010 | Garmin Rino 130 (14 Channels) 2-Way Radio
When i turn on the cb it does not light up and no one can hear me.
Check the in line fuse to make sure it is not blown. I would also check the cb pa switch
Jan 27, 2010 | Cobra 19 DX IV CB Radio
Adapting a 4 channel pa system to plug into a marantz cd310 digital recorder
What is the new Pa System Brand and Model. I am almost certain that every PA System sold has a stereo or mono out put and yes there are adapters to go from mono to left and right (stereo ) on your CD310 recorder. So, the simple answer is to look at the manual or even the back of the mixer to fins out where the audio is coming out of the mixer. The mixer on the pa system will mix the sources together for you. So, you might not need much of anything but a cord to get the audio to your recorder. You can send me the model number and I can give you the exact cord you need or you can take it to a near by store that sells audio pa systems and show them what you have and what you are trying to do and they will sell you a cord that will solve your issue.
Oct 30, 2007 | Marantz PMD670 Desktop Digital Voice...
Proview PA15BA7 15 in. LCD Television Logo
164 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
joncin91
Level 1 Expert
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
