Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My whirlpool Cabrio he washer says F1 when I try to wash
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&#@%
Posted on Sep 20, 2010
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
  • 1028 Answers
main control under console ..replace
Posted on Sep 19, 2008
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
  • 1382 Answers
SOURCE: why does F1 code show and the washer stop
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Posted on Jul 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: my whirlpool cabrio washing machine keeps flashing F1?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    I am getting a F1 code in my washer which causes it to stop several times during a wash cycle, what do I need to do?
    Hello;
    My name is Peter. I am a retired field service appliance technician.
    If you own a Whirlpool Cabrio and are experiencing an F1 error, you're unable to finish or start a load of clothes. When the Whirlpool Cabrio displays an F1 error, this means the the control board is having difficulty communicating with the motor.
    To fix your F1 error, you can first try to unplug your washing machine for 15 minutes and then plug it back in. If this doesn't work, you will need to replace the control board. The only tools that you need to replace the control board is a Phillips screw driver and a 1/4" hex head driver. Be sure to unplug the machine from the electrical outlet before performing any repairs.
    After unplugging your Whirlpool Cabrio washer, carefully pull the washer away from the wall (Watch your drain hose and the two inlet hoses.) Next unscrew the 3 screws located on the back of the Whirlpool Cabrio. Next, take a picture or make note of where each plug connects to the control board. Next, unplug each plug and the pressure tube. Lastly, unscrew the 1/4 screw then remove control board. Replace with new control board and reverse your steps to install. The new board will fix the Whirlpool Cabrio F1 error.
    Dec 08, 2014 | Washing Machines
    My whirlpool cabrio washing machine keeps giving me an F1 ERROR when it goes to the rinse cycle. It will complete the wash after i hit cancel reset and wash. Any ideas?
    F1(F68)-Pressure Signal Out-of-Range
    I telephoned Whirlpool at 1-800-253-1301. Whirlpool acknowledged the F1 fault and will send a serviceman, free parts and labor, to correct the problem concerning the "famous" F1 fault. This is even for washers out of warranty! This concerns model WTW6600SW2 washers. Be sure to get the authorization code from them so the service person cannot argue about costs.
    Jan 05, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Why does F1 code show and the washer stop on my whirlpool cabrio
    Thank you !!
    Jul 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 ERROR CABRIO MODEL WTW6400SW0 SER# CT2170433
    Please see the following Whirlpool installation and maintenance PDF on Cabrio washers. An F1 relates to a "primary control failure".
    It also has a very extensive troubleshooting section.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
    Oct 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
    63 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
