Question about Amana NED7200TW Electric Dryer
Dryer not heating up
With an electric dryer, you would have a heating element? and if so, would this go bad in just over a year? and how do you replace?
    Problem Solver:
  • 9 Answers
Is it turning and just not heating?? If so it could be the thermal limiter fuse , there are generally two in the back.
Posted on May 02, 2010
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 1122 Answers
SOURCE: Cabrio Electric Dryer Heating Element
have you checked the high temp thermostat?
Posted on Sep 05, 2008
TheMobilian
  • 8220 Answers
SOURCE: I need detailed instructions on how to replace
Very simple. Remove screws at the base and the front panel. The heater is on the bottom easily accessed. The re-string kit is way cheaper than the "mailbox" Start here:
Posted on Mar 04, 2009
jsrock516
  • 5911 Answers
SOURCE: what is cost of heating element of dryer
Prices vary by model number and parts resources. The element usually cost somewhere between $30 and $50. Here's a few websites you can use for reference to get an idea of how much a replacement element can cost:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed also have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
NOTE: In many cases, if you are experiencing a no heat problem, the heating element is NOT the problem. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
If you have already diagnosed your problem, great. If you need to reassurance so you don't spend money you don't have to, the following links can give you some tips on how to troubleshoot a dryer:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If you have any questions, please post back with your MODEL NUMBER so I can accurately determine how your dryer is configured. I hope you find this information helpful.
Posted on Mar 22, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
Posted on Apr 10, 2010
My two year old dryer will not heat. I cleaned out the lint filter and the duct. Those where not bad. I cant imagine if would be the heat element? What do you think?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 18, 2011 | Samsung DV328AE Electric Dryer
I have a Whirpool Dryer model 3LEN 2000PW1 It runs but does not heat?? Four years old. Could it be the heating element?
Hello there:
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Sep 29, 2010 | Whirlpool Dryers
I have a Kenmore Series 80 electrical dryer. It isn't getting hot/drying. I had this problem 4 years ago and the tech who fixed it said i shouldn't have the same problem for 10 years. Sounds like the...
The problem most likely is the thermal cut-off . This is the small t-stat lookin piece , located on the upper portion of the element housing . You can unplug the dryer , remove the 2 wires , connect them togather , plug the dryer back in , to test . If the dryer then heats , replace the thermal cut-off . If still no heat , then possible bad element . Also see
http://www.fixya.com/support/r4580247-whirlpool_or_kenmore_dryer_not_heat
Aug 03, 2010 | Dryers
Super capacity Amana dryer is less than 3 years old. It no longer dries the clothes. There is no heat.
check your heating element in the back of the unit for breaks, if there is not heat that is your problem. the other issue can be a fuse that blew not letting power get to the heating element but the easiest and cheapest thing to look at first is the heating element
Jan 10, 2010 | Amana DLE330RAW Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
No heat in a 1 year old Whirlpool ncabrio dryer
If there is no heat, it has nothing to do with the vent, but everything to do with the element. Yoiu either have a bad element or are not getting power to it.
Oct 05, 2009 | Whirlpool GEW9250 Electric Dryer
Electric dryer won't heat
The problem is most likely one of the thermal limit switches/thermostats which is bad -- there could be several of them. Or, it is less likely that it is the heating element or a loose/corroded/broken connection to the heating circuit.
I would call for service -- it would be less expensive than a new dryer.
Apr 21, 2009 | Dryers
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
Amana NED7200TW Electric Dryer Logo
420 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
