Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
After about 15 minutes of operation my mower just cuts off as though it ran our of gas but has not. I have replaced the ignition coil, spark plug, air filter, fuel filter. I have a 17.5 hp Craftsman riding mower.
I have same problem only thing ive found is gas tank may not be venting properly. Fill tank about half full and leave cap off, if still stalls then probably engine problem
Posted on May 05, 2010
Why does Mower cut off after running for a short period
Maybe some thing in the Carburetor or plugged fuel line? Worth a check
Jun 13, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Our Husqvarna YTH2148 mower has been in the shop twice and we can't figure out what's causing black, sooty fouling of the spark plugs.
Hi, change the engine oil. It has become contaminated with fuel. Also fit an inline fuel tap and turn it off whenever the mower is not in use. Basically the carby has leaked fuel into the engine oil, the engine then draws the fuel vapour from the oil through the crankcase vent into the carby creating the problem you have. Regards Phil.
Jun 03, 2012 | Husqvarna Garden
I have a 91 Chevy Lumina, just replaced the injectors and all the coils on saturday and ran fine but when driving it would have trouble it seemed shifting, starting today when you hit the gas the car dies...
Your ignition spark control module is going bad,your coils pack are located right underneth them. this is what tells your coils packs to produce spark to your spark plugs. they are easy to replace just make sure you mark you coil pack with some tape and make sure you put them back in the same order as they came off the spark control module. Easy to replace,just make sure you use the proper size torx or socket size on the screw heads...
May 31, 2011 | 1991 Chevrolet Lumina
Four stoke mower. Mower starts and runs ok but after a short time (10-15 minutes) the engine stops as though it has run out of fuel. Fuel tap on, filter clean, new spark plug. After a few minutes you can...
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
Dec 28, 2010 | Briggs & Stratton Garden
Crafstman riding mower cutting off now won't start at all
The two most likely suspects for the symptom you describe are:
a) Ignition coil failure under high heat.
OR
b) Decompression failure due to normal wear.
For a positive diagnosis try the following:
For scenario a)
Run the engine until it shuts itself down. As quickly as possible, check for spark using a spark tester (availabe at local auto parts store). If no spark when hot, allow to cool down and test again. If good spark when cold and no spark when hot, change the ignition coil.
Proper part number (assuming your machine is still all original) Briggs & Stratton part #492341.
For scenario b)
Run the engine until it shuts itself down. Try to restart but pay close attention to the speed of the spinning starter. Next, remove the spark plug and spin the engine over (WITH SPARK PLUG WIRE WELL OUT OF THE WAY!!) If the engine spins super fast and free you can discount the theory of a bad battery and you will need to adjust the valve lash.
Determine which is the case and reply to this post. I will gladly give a detailed explanation of the valve lash adjustment procedure in another post.
Hope this helps!
Oct 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower made huge cloud of white smoek and shut off . mower was cutting off after 2 minutes, filled oil, replaced spark plug, changed fuel fitler. mower ran about 5 minutes, then made backfire noise and a...
Check for spark at the plug.
If the engine has points and condenser . check to see if the points are good.
If electronic ignition, then it is likely the ignition module is the cause
Aug 02, 2009 | Garden
It Starts and runs fine for about 15 minutes then
I think that your right. Sounds like your ignition coil witch is most likely located under the the flywheel cover. I know that on some briggs and stratton engines they are actually under the flywheel, just trace the sparkplug wires to know for sure. When the ignition coil beginns to fail they start slowly (spitting and sputtering) and then they get to the point to where they stop firing after getting heated up and adventually quit all together.
Jul 27, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
407 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
