Question about Franke Work Top Double Bowl Kitchen Sink W/ Straight Front PRX720S
We cannot get the mounting clips to stay on - Franke Work Top Double Bowl Kitchen Sink W/ Straight Front PRX720S
    Problem Solver:
  • 7 Answers
I have spent several hours trying to solve the same problem with a Franke Granite double basin sink. The clips for this Franke sink appear to be a piece of engineering garbage, and the instructions are utterly useless - A huge piece of paper with a template, and tiny pictures that look like they were drawn by a kindergartner with a crayon. The instructions for using the clips --oh there are none - other than a blurry picture in which the clips could fit inside this period (.). Lots of other people appear to have the same issue. I like the Franke sink, but without proper mounting hardware, this franke sink is no better than the poorly made clips, and the Franke Sink horrible instructions that it came with.
Posted on Jan 22, 2011
I agree that the Franke clips are useless. I dropped the sink into an existing and poorly cut hole in my counter top. I then attached wooden blocks under the sink on all four sides between the sink and the cabinet walls on either side. The blocks, which are only 4 or 5 inches long, are screwed into the cabinet walls and prevent the sink from moving in any direction. No other attachment is necessary.
Posted on Dec 06, 2012
  • hdavid9
    hdavid9 Dec 06, 2012
How to clip the temperature sensor in place
There are usually small stays that go around the sensor bulb and fit into the oven cavity ceiling or wall, did you lose the stays? use your model # and search a parts site for the clips. Mounting Clip 316278300
May 13, 2016 | Ovens
Brake lights stay on
the brake light switch attached to the pedal has gone bad this is what it looks like there is a hair pin clip that holds it in place on the frame mounting flange of the pedal unplug it pull out the hairpin clip slide it off reverse removal
Mar 05, 2015 | 2004 Ford Explorer
The door spring came off of hamilton beach 31100
The door of the Hamilton Beach Model 03008 or similar toaster oven does not stay closed when the door return spring or the hook it connects to breaks. The repair is very simple and takes just a few minutes!
The door spring is about 1 inch long and connects to a small clip on the inside of the left side panel of the unit. To see the small clip and the door spring, you simply remove the left side panel of the toaster oven which is done by removing just one screw.
The mounting clip on the side panel for the door return spring is located about half way up the side panel near its front edge.
The other end of the spring (its bottom end) connects to a metal hook. If the spring is not connected on its bottom end then the wire hook is broken. This is a simple repair that only requires a few inches of metal wire.
The other end of the metal hook (its bottom end) is connected to the bottom of the door hinge where it inserts into a small hole in the left side mounting hinge of the door.
When the steel hook breaks on either end then the spring cannot function, so the door does not stay closed.
To fix this problem, you simply get a piece of steel wire that is about 1/16 inch thick and a few inches long.
Bend the wire to make a hook at one end that the spring will connect to.
Then insert the other end of the wire into the small hole on the left side mounting hinge of the door. Then bend the wire on the inside of the hole to make a U or hook so the wire stays mounted in the hole of the door hinge.
Then adjust the position of the bend on the other end of the metal wire so the spring will have good tension when it is attached to the hook and to the clip on the side panel.
To do this you make the U shaped bend on this end of the wire to be about 1/2 inch from the end of the open end of the spring when the top end of the spring is attached to the mounting clip on the side panel.
To attach the spring to the wire hook, first remove the spring from the mounting clip. Then hook the spring onto the hook (bend) you made at the top end of the wire, then just stretch the spring to connect it to the mounting clip. The door will now stay closed.
Nov 10, 2013 | Hamilton Beach 31197 120 Watts Toaster...
I have a Kenmore Refrigerator/freezer, model # 59673503201. The freezer door was dented, so I ordered a new one, which arrived without a handle. I removed the 8 screws on the inside panel and attempted...
The handle is held by screws and butter clip. You removed the screws,but also release the clips.If in case the clips break during removal,then you can replace the clips too.The cost of each clip is $2.There are two clips in total.One clip on each side of the handle.Once you release this clips the handle should freely come out.To see how the clips look.See the fig below:-- helpmech_57.jpg
This clips are called butter clips or mounting clips.To order this clips if required.Please click on the link below:---- http://www.repairclinic.com/PartDetail/Mounting-Clip/1023807 -------------- If you want door handle removing diagram for your refrigerator: Click on the link below:--- see the diagram:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00001.png ---------------- If you require new handle then click this link directly:---The cost of new handle is $21.----- http://www.repairclinic.com/PartDetail/Handle/1070320 ------------ Also for more help,if you require,freezer door disassembly diagram.Please click on the link below:--- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/M0307112-00004.png ---------------- This should help.Thanks.Helpmech.
Jan 26, 2011 | Refrigerators
Need to stabilize machine and have granite countertops
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Nov 20, 2010 | Siemens 24 in. SL84A305UC Built-in...
Mounting my dishwasher to granite counter tops. Granite Grabbers last about a week before they loosen up
Oct 21, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Just did a kitchen remodel, kept the Bosch dishwasher model SHU9955UC, contractor having problems will attaching dishwasher to granite. Any suggestions? Thanks!
Sep 24, 2010 | Bosch SHU9955UC Built-in Dishwasher
What dose the crank sensor look like and where dose it go on a 99 dodge dokota
Please don't forget to rate!
  1. Remove the air cleaner assembly if necessary for access to the sensor.
  2. Disconnect the pigtail harness from the sensor.
  3. Remove the nut holding the sensor wire clip to the fuel rail mounting stud.
  4. Remove the sensor mounting hardware, then the sensor.
  5. Remove the clip from the sensor wire harness.
To install:
  1. Install the sensor flush against the opening.
  2. Install and tighten the bolts or nuts, as applicable.
  3. Install the electrical connector.
  4. Install the clip on the sensor wire harness.
  5. Install the clip over the fuel rail mounting stud. Install the clip mounting nut.
These 4 pictures are for the Automatic:
These are for a manual trans:
Mar 06, 2010 | 1999 Dodge Dakota
How to change a front headlight
First, open your car hood, then right behind the headlight unit, you will notice two clips per side, they are long and straight with a hooked end. Using the hooked end, just lift the clip up and move it away from the headlight, the left (when facing the front) clip will be between the headlight and the battery cover.
After taking out the clips, the headlight will be loose from the car. Look behind the headlight and you will see the wires running into the actual light to the bulb. What you would do is twist the light out (I believe counter clockwise) and the bulb will come out with its mount. Then unclip the bulb from the mount. Then just put on the new bulb and make sure the sides clip into the mount.
Then carefully put the mount and bulb back into the headlight unit and then twist it in clockwise, you will feel it go in properly, if not lined up properly, it will not be smooth and won't stay in place.
Then put the headlight unit back into place, and secure it back to the car with the clips you removed.
Note: Make sure not to touch the actual glass of the new bulbs as this will make them last a shorter period of time. Good luck
Nov 04, 2009 | 2001 Chevrolet Blazer
How to remove the base from the monitor
For monitor or TV bases that have four clips, I found if two people each take two opposite clips, and use thumbs to push in the clips, we can pop the base off fairly easily. It is impossible with one person, since thumb and forefinger can't exert sufficient pressure on the clips.
Jul 18, 2007 | Acer AL1717 17" LCD Monitor
Franke Work Top Double Bowl Kitchen Sink W/ Straight Front  PRX720S Logo
1,251 people viewed this question
Top Franke Home Experts
Donni Steen
Gil Shultz
Freddy
Are you a Franke Home Expert? Answer questions, earn points and help others
