Question about Minolta DiALTA DI2510F All-In-One Laser Printer
Minolta dialta di251
I need a nic card for scanning purposes.
The in the copier is bad
Help........
  • Minolta Master
  • 6,850 Answers
SOURCE:
  • 8 Answers
SOURCE: Connecting my Di251 to the finisher
Make sure the actuator pin is still attached to the mid left section of the copier. It's a metal pin about 3 inches long (we call it the "shwartz", ha,ha) that is inserted into the finisher when the finisher is pushed close to the copier.  It is normally mounted with 1 or 2 screws.
Posted on Oct 21, 2007
  • 300 Answers
SOURCE: Hello, Our Minolta Dialta Colour Copier/Printer
C0208: PC Drum Charge Corona malfunction. The SCD signal is detected for a continuous 0.7-sec. period while the PC Drum Charge Corona is being energized.
Relevant Electrical Parts - Image Units C/M/Y/Bk, High Voltage Unit (PC Drum CH.) HV1 IO Board (PWB-IO)
Steps (in this order) - Check the Image unit contacts and correct
or clean as necessary.
Check the HV1 contacts and
correct or clean as necessary
Change Image Unit.
Change HV1.
Change PWB-IO
Posted on Aug 13, 2008
jqsababa967
  • 145 Answers
SOURCE: minolta dialta di181 c1300 error
C1301 errors after setting up the Di181.
Solution:
Replace PWB-A, part number 1177-0106-03 for C1301.
Posted on Oct 21, 2008
  • 1383 Answers
SOURCE: I need driver for Windows xp for Minolta Dialta Di350
click here
you can downlaod install in computer
Thanks please let me know.
Posted on Jul 27, 2009
  • 26 Answers
SOURCE: C0500 error in a minolta Di251
Does the lid over the toner bottle close properly?
Posted on Mar 05, 2010
Re DiAlta di 251
What about the Di251?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 03, 2014 | Minolta DiALTA Di183 Copier
Di251 driver
The best driver s you mite find for the Di251 is 95 or xp Di251 series is legacy Minolta now konicminolta try their web site but doubt you will find it
Jan 15, 2014 | Minolta DiALTA DI2510F All-In-One Laser...
C1300 code on dialta Di251
print head failure. print head houses the LASER. Check the connection between the LASER (Print head and the control board. CHECK FOR BENT PIN
Nov 12, 2012 | Minolta Office Equipment & Supplies
How do i replace imaging unit minolta dialta di251
open the right side pull out the old one bye two handles install the new one
Apr 03, 2012 | Minolta Di251 All-In-One Printer
I have a Minolta Di351f printer that keeps failing to send scanned documents over FTP. After several restarts it eventually comes back to normal and sends the documents properly again. Is there anything I...
This is somewhat common on these aging machines. The NIC card in your Pi3502 print controller is going bad. It is a common symptom when this happens that print jobs and or scanning jobs take forever to print/send or will stop altogether. The only fix is to try and find another NIC card for your Pi3502 Print Controller. But this can be risky as even another NIC may not work or work for very long as they are getting to be about 8 years old now. I have had to upgrade a few of my customers from the Di251/351 because of this issue.
Good Luck and Thank You for using Fixya.
Aug 30, 2010 | Minolta Di3510f Bizhub Copier
Reports keep on printing!!! Minolta Di251/351
You need a service technician to down load program that will stop it. Its on service web site
Mar 27, 2009 | Konica Minolta DiALTA Di200 Copier
FAx
Minolta had two models, Di251 No Fax.
And the other was the Di251F, with fax.
It is not something easily or cheaply changed,
Hope this is of some help.
Sep 10, 2007 | Minolta DiALTA DI2510F All-In-One Laser...
Open Questions:
See all Minolta DiALTA DI2510F All-In-One Laser Printer Questions
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
85 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
