Question about Toshiba 27A40 27" TV
TOSHIBA 27A40 TV
TV IS NOT RESPONDING TO THE REMOTE, I HAD THE REMOTE
CHECKED OUT IT IS FINE, IS THERE A REMOTE MODULE? HOW HARD IS IT TO REPLACE? THANKS
  • 129 Answers
Good day.
if your remote is not responding to your tv and you were able that your remote is good, then there must be a problem with your tv.
I suggest that you have your unit be checked by a repairman. No matter how many remotes you buy, if the problem is within your tv, it will not be resolved.
chris
Posted on Mar 29, 2008
My Toshiba TV, Model 57HX81 quit responding to any remote control. How do we repair that or how much will it cost to have it serviced?
Does the rest of the TV work fine? If so, the problem is likely with the remote control. Have you replaced the batteries and made sure they are installed correctly? Did batteries recently leak in the remote to where the new batteries may not be making good contact with the metal springs? Has the remote been dropped a lot? If so, a solder joint may be broken for the IR transmitter.
If you have a universal remote that can be programmed to the TV model, that should make it easy to confirm if the issue is the remote or the TV.
Nov 26, 2016 | Toshiba Televison & Video
My Toshiba mv13n3 tv/vcrnot, tv responding with the remote.
point the remote at a camera an watch is the led blinking when you push button
or take it to autozone they have a remote tester
Oct 19, 2014 | Televison & Video
Tv not responding to remote control
Check the remote control for its infrared emission. Check it with fresh batteries. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Details about how to check a remote control are given. If the remote control is found OK, check and replace the infrared sensor inside the TV.
Dec 03, 2013 | Toshiba Regza 37HL17 37 in. LCD TV
Remote control senser failure in tV
It can be replaced. Contact any service tech:.
Mar 23, 2013 | Toshiba 36A41 36" TV
Toshiba 32A43 - suddenly stopped responding to both my Toshiba CT-90157 remote and Verizon FIOS Philips RC 1445301 remote. Replaced batteries in both remotes & tried to reprogram the Verizon remote...
hi
this kind of problem is usely comming from one of the front panel button if so the set will show the menu intermitently and no action from the remote. What i use to do i replace
all of the tack switches 6or 7 but i would suggest to consult your local tv repair shop if
you do not have some kind of experience.
Sep 28, 2010 | Toshiba 32A43 32" TV
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
Remote control not responding to tv
You need to program the remote to work with the TV. And I hate to point you this way, but I've looked around for the manual on this remote, and can't find it, so, go to the Toshiba website and email Customer service that you have lost your manual for the remote. See if they will email you one. I bet they will.
Jan 30, 2009 | Toshiba 42H81 42" Rear Projection...
Remote sensor not working
either the sensor on the tv is going or the eprom chip will need to be replaced along with a crystal that is on the chip
Dec 10, 2008 | Toshiba 32AF43 32" TV
Remote i on tv
From elsewhere... in case it helps
"...and an intermittent problem responding to the
remote. I had a service person check it out and was going to have it
repaired because it still looks and sounds very good. The part was
available at a cost of about $85-90 plus about $40 for the service.
However, the service person didn't want to come back again for
another service call because I was too far and it was not profitable
for him, so the part was never replaced.
The remote control is OK. It is the receiving module in the TV that
has a low voltage problem. If anyone is electronically handy it
probably is an easy fix to install a new module or it can be use
without the remote with the buttons on the TV."
Aug 03, 2008 | Toshiba 36A61 36" TV
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Toshiba 27A40 27" TV Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
