Question about Mitsubishi WS-55859 55" Rear Projection Television
When hit the power button the timer light just blinks and the TV does not come on. any ideas?
  • jgiza Jul 11, 2012
    I replaced caps and the ty will turn on for about a minute but the front buttons won't work. Then it will power off and blink green. This can be repeated. I reset the system, still same thing.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on May 02, 2010
2006 mitsubishi tv WD 62627. Tv wont come on i hear a click when I hit the power button. Blinks green on timer for about 60 sec then goes to solid yellow light on status. Error code 46.blew fan out.
Those blinks are fault indications. From the number of blinks occur at one time switch on, you can get an idea about the fault circuit section inside it. http://electronicshelponline.blogspot.com/ Visit the site linked here to know more details about the blinking codes.
Feb 18, 2017 | Mitsubishi Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv wont turn on. red timer light blinking. i think our baby hit some magic button.
I have a Sony Trinitron KV-35S66 36" TV my Stand by/Timer Light keeps flashing, I have tried all fixes, it's 9 1/2 years old is is worth fixing/cost.......no money!!!!
Jan 02, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
We plugged in the tv and hit the power button the green timer light blinked for about a minute. We hit he power button and it stayed on for about 5 second and turned off. We just bought this tv used and...
This is a common problem with this kind of tv. When you give the unit power the green light will blink because it is telling you that the projection lights are warming up. Sometimes it will take up to a minute. When you hit the power button again after only 5 seconds it told the tv to power off. I hope this will help you out.
Nov 23, 2008 | Televison & Video
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Mar 18, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Tv not working
u need to repair your tv from a technician. there is a problem in the internal circuit of your tv
Mar 09, 2008 | Sony KV-27S45 27" TV
Mitsubishi WS-55859 55" Rear Projection Television Logo
506 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
