Question about Samsung Digimax D53 Digital Camera
Camera Won't Turn On
My Samsung Digimax D53 digital camera has stopped working. I've tried 3 different battery changes, Alkaline and non-Alkaline batteries. I've plugged it into the computer, but it still won't turn on. Any advice
  • 2 more comments
  • SCORPION67 May 31, 2008
    camera turns on for a second, then beeps loadly. can see the screen for just a sec. then it shuts off won't come back on...HELP??? D53 DIGITAL
  • Anonymous Jun 03, 2008
    I just got my camera in dec.2007.My camera hasnt been working since last month,it wont turn on and we've tried changing the batteries(we use rechargeable batteries)and it still isnt working...what do i do?
  • beemerboy Jun 05, 2008
    camera wont turn on. batteries are good.
  • Anonymous Jun 09, 2008
    Having the same problem - camera turns on for a second, then beeps loadly. can see the screen for just a sec. then it shuts off won't come back on... seems to be a common defect?
If your having battery problems then i suggest recharables...i got energizer AA rechargeable set and it works perfectly for me...hope this helps :D
Posted on Mar 30, 2008
Where can i find new samsung model: SNB-2312 batteries for my samsung Digimax D53 camera?
This camera takes AA size batteries, which can be rechargeable or just disposable Alkaline cells. You would have got a set of alkaline AAs with the camera, and when these expire, you just put in a fresh set, that you can buy anywhere. They don't need to be Samsung. DON'T use cheap zinc or "long life" AAs, though. They are not up to the task, and can leak and corrode your camera.
NiMH batteries with a capacity of 2700mAH are available, and these will last longer, per charge, than name brand alkalines, as well as being rechargeable. You can buy these with a charger fairly cheaply now (though they obviously cost more than disposables). You will probably want two sets, one to be on charge while you use the other.
Nov 22, 2010 | Samsung Digimax D53 Digital Camera
Tip
Short battery life with AAs or camera won't even power up on new batteries?
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Nov 09, 2007 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 Camera says low battery but just replaced with brand new ones. Camera beeps and shuts down immediately.
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Jul 22, 2009 | Samsung Digimax D53 Digital Camera
My samsung want turn on
Hello!!
Try hard resetting once.. remove the batteries and press the power button for few seconds and later start up the camera .. let me know if it works !!
Thank you!!!
Jan 12, 2009 | Samsung Digimax D53 Digital Camera
Recently changed the battery and now everytime I shoot a picture the camera goes off and has to be re-powered back on to take another. Now, it won't power back on.
you need to check that you have put in the correct type of battery. Some cameras will only work with alkaline batteries.. I had this problem with my samsung when i inserted zinc batteries instead of alkaline, I use duracell cause they are pretty good for taking lots of shots before running out.
Dec 23, 2008 | Samsung Digimax D53 Digital Camera
Need to know what battery the digimax d53 uses
I use alkaline batteries on my samsung camera, the better quality battery the longer they will last.
I hope this helps
Nov 30, 2008 | Samsung Digimax D53 Digital Camera
refer to my answer I gave to:
bsnydto
why does my camera say low battery...
seems to be the same problem
Jun 20, 2008 | Samsung Digimax D53 Digital Camera
Camera wont turn on unless i take the batteries out
I tried alkaline batteries in this camera and it would only work for a few pictures, then it would go unstable and do unpredictable things. The lithium batterys also caused problems like the ones you described. As a last resort I found that there was a ni-mh battery for this camera. I could not find this accessory. I purchase some batteries and charger then installed them into camera. reset the camera using the reset function, then tested camera. It now works correctly and consistantly takes good pictures. If the camera does not work with the ni-mh batteries it might be damaged or bad.
Jan 29, 2008 | Samsung Digimax D53 Digital Camera
Camera won't turn on
use a lithium or nimh battery and it should work. regular alkaline is not good in this camera
Dec 13, 2007 | Samsung Digimax D53 Digital Camera
Camera will not turn on
Are you sure the batteries are fully charged? I would suggest using rechargeable not alkaline batteries.
Samsung Digimax D53 Digital Camera Logo
93 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
