Hi i have a bose lifestyle 48 system and i changed the setting to european standard and i have no picture now. How do i change it back
  • 3 more comments
  • wtchernichan May 02, 2010
    well im actually not to sure, do you Know how to tell which one it is?
    well it says AV 48 media system on the bottom and the date is 2007. Does that help?
    Yes it does have that
    yes it does
    ok so you mean the setup and demonstration disk right? and we got it of the european setting but the screen is still black with the HDMI cord and the screen is green when we try all the other cords (component, s video etc)
    Master:
  • 497 Answers
I have been doing some research but I need to know EXACTLY which Lifestyle 48 System you have.. (i.e: Series I, III, or IV?) Please let me know so I can help you more appropriately, OK? Thanks- LUCKY4LYNN2 :)
Posted on May 02, 2010
  • 2 more comments
  • Lynn Carmody May 02, 2010
    look at the Manufacturer Sticker for the Model # and/or Production Date.
    Yes, thank you. Does it have the VS-2 Video Enhancer?
    If I am right, you received (2) SETUP DVD's.. Is that correct? If so, try doing the setup & install again and we'll see if that takes care of the problem. ok?
    Yes, do the setup disks again
DVD Format Problem in Bose LS 48
Follow this button sequence press when the error message appears"
Right Navigation - Up Navigation - Shuffle - Stop - Mute
this is make is play all discs.
Jul 27, 2009 | Bose Lifestyle 48 System
Tip
Reset Bose LifeStyle 48 VChip Password
Bypass or Reset Bose LifeStyle 48 System V-Chip Password Lock
Would you like to bypass, defeat or reset your Bose LifeStyle 48 System Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked signal without entering your password.
When your passcode is requested, enter the temporary code 2673. This process temporarily unlocks your system, and you can reset or change the password.
I hope that helps.
_______________________________________
Bose LifeStyle 48 Manual Download
Bose LifeStyle 48 Video Mode
on May 02, 2010 | Bose Lifestyle 48 System
Tip
I hope that helps.
on May 02, 2010 | Televison & Video
Bose Lifestyle 48 System play's dvd in black & white only also connect to vs-2 video enhacer hello, my bose lifestyle 48 only plays DVD's in black and white. I can't find a setting or a reason why it...
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
May 31, 2009 | Bose Lifestyle 48 System
Open/close tray disc stuck bose Lifestyle 48
Problem:
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Solution:
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
Tip
Bose LifeStyle 48 System Video Mode Change
Follow these steps to change the video setting from European to North American:
With the media center turned off, use the controls on its front panel to follow these steps:
  1. Press and hold the Enter button on the media center.
  2. While holding the Enter button down, press the Store button. Selections will appear on the media center display each time you press Store.
  3. When Video appears as the selection on the display, release the Store and Enter buttons.
  4. Use the Volume up and down buttons to scroll through the Video options.
  5. Stop scrolling at the proper selection:
  • For a component connection only, select:
  • -NTSC COMPONENT (in N. America)
  • -PAL COMPONENT (outside North America)
  • For a component connection and progressive scan, select NTSC PROGRESSIVE.
6. With the proper selection made, press Store to confirm the
selection and leave the Video options.
I hope that helps.
Tip
Download Bose LifeStyle 48 System Owners Manual
Have you misplaced your Bose LifeStyle 48 System Users Guide?
Would you like a digital, searchable, pdf version of the Bose LifeStyle 48 System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
Incompatible Video Signal
i forget exactly how to do this, and i know how to do it, but your menu should still display on your tv when you press the menu button. but,,,,
worse i did it in a hotel and had to get engineering to fix it for me....
you need to reset the system, the instructions are in the manual,
but to get your picture dislaying on your tv, get an adaptor for the end of your scart cable and plug the yellow video component into the AV socket on your TV. this should work until you wade through the manual. even though the picture wont be good.
Mar 01, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
Tip
I hope that helps.
Tip
I hope that helps.
 Grubhead
Grubhead
