Question about Logitech ClearChat Stereo Headset Headset
My mic isn't working on Ventrilo
It is plugged in the right jacks but it just will not work. Is something wrong with the output device? Because all it has there is a Sterio Mix.
3 Suggested Answers
  • 8 Answers
SOURCE: mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Posted on Apr 07, 2009
  • 6 Answers
SOURCE: cant hear but mic works
Ventrilo has an excellent forum system and I am sure you will find an answer there.
Posted on Apr 16, 2009
Bought turtle beach z11 headset, cant get mic to work
The Z11 has a four-pole input/output plug to connect the mic and the earphone. The earphone needs to be connected to the earphone jack and the mic needs to be connected to the mic input jack on the back of the computer. In other words, you should have to 3.5 mm plugs. Plugging both into the same jack will disconnect one or the other. Check your adapter, It should have two separate 3.5mm plugs. If it does, be sure they are connected to the right jacks on the computer. The headphone jack will have a headphone symbol; the mic jack will have a microphone symbol. Go to System Preferences, Sound. Select the line in preference for input and the line out preference for headphones. Just may work.
Mar 14, 2014 | Apple iMac G5 Desktop
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
I plug it into the headphone jack in my cd player but it doesn't seem to work ? what am I doing wrong
Think of the "headphone jack" as an OUT, while a microphone as an IN. Can't put something into an output.
You not only would need an IN, but the correct level input as well. Microphones require a preamp to boost the signal level to line level. Depending on your microphone (condenser) you may also need what is called "Phantom Power" to power the mic.
I hope this helps,
Magoo
Mar 07, 2011 | Sony FV420 Consumer Microphone
My mic isnt working but i can hear out of my headset
If you are running Vista, make sure that you set your mic as the default. Then check on vent settings and make sure that your output setting are set for your head set. You can then test your headset inside of the settings tab.
Jan 27, 2010 | Genius HS-04SU Headset
Headet and desktop microphone problem.
first check if you have the right drivers on your computer for your audio, if you have audio like mine go to realtek audio manager it should be right beside the clock, then click on the top right corner it says device advanced settings it opens another box that gives you options for recording like tie up same type of input jacks, ie. line-in or microphone,as an input device. and it has another one separate all input jacks as independent input devices you could try one of those if you have realtek audio manager theres other options to that might help and if you dont have that go to recording devices and see if your mic is working properly and if its set to default device
Apr 25, 2009 | Logitech USB Desktop Consumer Microphone
Mic not working in ventrilo after I installed new video card
You probably need to upgrade your drivers too....let us know if it works, and please be kind when ranking.
Good Luck
Apr 12, 2009 | Computers & Internet
My mic is recording sound from the headphones, NOT the mic piece, why is this?
-right click on the volume icon on the system tray and select recording devices
-there should be a selection that says stereo mix or something like it
if not.. right click on a blank space on that box and select "show hidden devices"
-you must disable this device
-make sure your microphone jack is enabled
-click apply and it should work
Apr 12, 2009 | Microsoft LifeChat Stereo Headset with...
I jus bought a brand new mic because i thuoght my other one was broke to use for ventrilo. but now when i plug in my mic and head set it keeps saying its plugged in and unplugged. and before that when i...
Do you have Window's Vista...I'm not sure if it works the same way, but I had the same scenario and I simply went to audio manager in my toolbar (the speaker looking thing making sound waves) and made all of the input jacks apart from each other. Go to Device Advanced Settings and choose Separated input jacks.
Sound Manager > Advanced Device Settings > Separate all Input jacks as Independent Devices
Apr 06, 2009 | ASUS M2N-E SLi Motherboard
Trying to use a microphone but not sure how to hook it up
No because the mic is a signel in device and the headphone jack is a signal out jack! meaning if you plug the mic into it the mic will act as a speaker and music will come out of it and ruin it!
I would buy an adapter at radio shack and plug it into the phono input on the back of unit! and if you dont have a phono input you will need to buy a small pre-amp and plug it into the aux or tape input!
That will work!
Please rate my answer!
Thank You!
Jan 16, 2009 | Samson R21S Microphone
Headset paired but doesnt function in ventrilo
Did you ever figure out what was wrong. Mine is doing the same with my LG shine. I will have to take it in for service. You had the problem quite awhile ago. Hoping you got an answer.
Oct 24, 2007 | Jabra BT125 Headset
Logitech ClearChat Stereo Headset Headset Logo
606 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
