Question about Jenn-Air JCD2297KEY 36" 22 Cu. Ft. Floating Glass Side-By-Side Refrigerator w/ TriSensor Electronic ...
How much is the refrigerator? - Jenn-Air JCD2297KEY 36" 22 Cu. Ft. Floating Glass Side-By-Side Refrigerator w/ TriSensor Electronic ...
    President:
  • 2,049 Answers
MSRP: $2,769.00
Online pricing in the $2,300-$2,500
Posted on May 02, 2010
Refrigerator is not getting cold freezer is
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
Tip
How to troubleshoot and, repair your RV refrigerator
if this is a gas absorption refrigerator make sure it's level while operating.
check for heat at the roof vent if no heat check heating element or, gas burner behind the refrigerator accessible through the refrigerator outside hatch; next: check the relay and, inverter it is located under the refrigerator front if all these things check ok and, especially if you find a yellow power on the gas refrigeration unit the tanks behind the refrigerator box; you must replace the gas refrigeration unit by: removing the refrigerator from the cabinet from the front then lay it down and remove the gas refrigeration unit replace it with a new one but, don't forget to remove the 3' long spiral metal strip from the old gas refrigeration unit exhaust vent and, reinstall it in the new gas refrigeration unit the gas refrigeration units can be purchased online.
on Jul 17, 2010 | Refrigerators
Tip
What a refrigerant mean
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Understanding Refrigerants
Before I start up my topic I will like to explain what the word refrigerant means and other things that I fill you have to know more on the subject matter.
What are refrigerants? Refrigerants are fluids that absorb heat at low temperatures and rejects heat at higher temperatures. The principles of refrigerant allow for heat pumps and straight air conditioners to function properly; because of their pressure temperature relationship. This relationship allows for heat transfer.
In the HVAC industry refrigerants are given a trade name known as "R" names. Examples of these names are R22, R134a, and R502. These names help to describe the different types of refrigerants. Refrigerants have various chemical make ups, along with different properties. Some refrigerants are only able to work in high pressures while others use low pressures to function properly.
There are three main make ups of refrigerants that are currently used. Hydrogenated Fluorocarbon Refrigerants (HFCs), which is made up of hydrogen, fluorine, and carbon. Because they do not use a chlorine atom (which is used in most refrigerants) they are known to be one of the least damaging to our ozone. Hydrogenated Chlorofluorocarbon Refrigerants (HCFCs), which are made up of hydrogen, chlorine, fluorine, and carbon. These refrigerants contain minimal amounts of chlorine; they are not as detrimental to the environment as some other refrigerants. Chlorofluorocarbon Refrigerants (CFCs), which contain chlorine, fluorine and carbon. These refrigerants carry high amounts of chlorine so they are known for being the most hazardous to the ozone layer.
Sometimes refrigerants consist of a two or more chemical compounds. These blends break down into two types: Zoetrope’s and Azeotropes. Zeotrope A zeotrope is a liquid mixture that obeys Raoult's law. It shows no maximum or minimum when vapour pressure is plotted against the composition at a constant temperature.Zeotrope refrigerant mixes are mainly made of three different types of refrigerants. The characteristic that describes this type of refrigerant is that all three refrigerants keep their own properties; they act as 3 individual refrigerants. Azeotropes are mainly a blend of two refrigerants. The property that defines this type of refrigerant is it acts as a single refrigerant. This effect the boiling points of both types of refrigerants.
The most important fundamentals of refrigerants before expanding into how they work. This key principle is that refrigerants do not make things 'cold' they remove heat. This principle is preached in the HVAC industry. It is a common misunderstanding of homeowners and technicians.
A pressure temperature relationship is a way of describing the specific temperature that relates directly with the pressure of a substance. This allows control of refrigerants boiling temperatures. Controlling a refrigerants boiling temperature allows for proper heat transfer.
Heat transfer is when heat from one place is transferred to another place, this is also referred to as a refrigerant cycle. Generally we control heat transfer through air, water and refrigerants.
This type of heat transfer happens through conduction. Conduction is when heated molecules, with lots of movement, collide with slow moving molecules. The warmer molecules, fast moving, always move towards the cooler ones, or the slow moving molecules.
Refrigerants are sold in disposable container that includes a check valve. This limits the reuse of old refrigerants and prevents mixing refrigerants. Refrigerants are identified by a standard color code. The labels also contain information on which type of refrigerant is in the container along with any safety hazards there are.
There are several safety hazards when handling refrigerants. In order to help prevent damage to the ozone, technicians are required by law to become EPA certified. There are four (4) main types of certification; Type I, Type II, Type III, and UNIVERSAL. Type I includes small appliances such as refrigerators. Type II includes high pressure appliance with the exclusion of small appliances such as split-systems. Type III includes low pressure systems such as chillers. A Universal certification includes all three types of certifications. For more information on refrigerants, their properties, how they effect the environment, and becoming certified.
on Feb 26, 2010 | Refrigerators
Maytag MFD2560HEW refrigerator. Refrigeration section not cooling... Freezer appears to be fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jan 15, 2011 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator motor is runnung but both thr frezzer and refrigerator is not cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Dec 11, 2010 | Maytag PTB1953G Top Freezer Refrigerator
The freezer works fine, refrigerator section not cooling it is 6 yrs. old, should it need a refrigerant(freon) charge ?
heatman101
Nov 09, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Refrigerator cold ice on ceiling no air to refrigerator and its warm the fan not turning
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 19, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerator is not sufficiently cold. Changing
heatman101
Jul 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
JCD2389G Side by Side Refrigerator: REFRIGERATOR SIDE OF SIDE BY SIDE REFRIGERATOR NOT...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 17, 2010 | Jenn-Air JCD2389G Side by Side...
HOW DO REFILL FREON IN IT
Is your entire refrigerator not cooling?
Refrigerant service must be performed by a certified refrigerant specialist. Are you certain that you need refrigerant? If refrigerant is required, then you have a leak. Normally, refrigerant should last for many years without requiring new refrigerant (sealed refrigeration system). Your problem may be attributed to one of the following:
* compressor
* components attached to compressor: relay, capacitor (if applicable) and/or overload protector
Contact an appliance service company.
Feb 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Jenn-Air JCD2297KEY 36" 22 Cu. Ft. Floating Glass Side-By-Side Refrigerator w/ TriSensor Electronic ... Logo
69 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
