Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
Power light flashes red
I changed lamp and now the power light flashes red what does that mean
  • Sony Master
  • 5,138 Answers
Check the Lamp Fan if it is OK then you need to replace Ballast Board it is what powers Lamp.
UED 1-800-648-6657 or Encompass 1-800-638-3328
Posted on May 02, 2010
4 Suggested Answers
  • 1153 Answers
SOURCE: WD-62327 Lamp
Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977020 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977020 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977020 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001
Posted on Sep 18, 2007
  • 68 Answers
SOURCE: flashing red light saying lamp and no picture.
REPLACE LAMP !!!
Buy an Orginal Replacement Lamp.
Posted on May 19, 2010
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
Check out this manual. https://panasonic.ca/PCS/OperatingInstructions/PT43-50-60LC14K-OI-Eng-Fr.pdf Warning lights is defined would be same for dlp.
Posted on Oct 22, 2011
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
May 05, 2017 | HP Computers & Internet
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Sony VPL-DX100 projector red light blinking first focus coming after 20 second focus off than red light blinking now how to solve this problem
light is in red means standby mode.
Flashes in red - The projector is in abnormal status. Symptoms are indicated by
number of flashes. Address the problem in accordance with the
following. If a symptom persists, despite having taken measures below, consult with qualified Sony personnel.
Dec 04, 2015 | Sony Office Equipment & Supplies
My mitsubishi flashes a red light what does that mean
Red light is usually lamp indicator---may be time to replace the lamp--they have a 2000 hour life span except for generic ones which last half that long----when was lamp last replaced? also the set does have a self check:
After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 30, 2012 | Mitsubishi WD-60737 60 in. HDTV
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Power Light Flashing Red
Change the lamp. If red led is flashing 4 times. replace lamp fan.
Apr 22, 2009 | Televison & Video
Panasonic PT 50LC14 problem
You have to close the lamp door. It has a switch in it much like a clothes dryer door in that when it is open it wont operate.
Feb 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
608 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
