Question about Kenmore 24032\24036 Top Load Washer
Broken lid switch on washer
The lid switch on my washing machine broke. I have ordered the part. Now I am wondering how to repair it.
    Problem Solver:
  • 5 Answers
You must take the cabinet off by removeing the screws from the consloe and flip it back and remove the 2 clamp,s and remove the cabinet and replace lid switch
Posted on May 02, 2010
Testimonial: "I was hoping removing the cabinet was not necessary, but I will give it a shot. "
Washer Lid broken
should be able to order parts from www.searspartsdirect.com. Should be a parts breakdown to look at and pick what you need.
Feb 21, 2015 | Kenmore Washing Machines
HI I HAVE A KENMORE WASHER MODEL #82881100 SERIAL #C92167486 THE WASHER FILLS AND NOTHING ELSE.DOESN`T AGITATE,SPIN OR DRAIN. THANK YOU IF YOU CAN HELP. BOB
you forgot the first three 110.82881100 is the full model,you'll need that to order the right parts.it sounds like you have a broken lid switch,i looked up your machine and it takes the older cherry switch part number 279347 and it's around 35 dollars.close the lid down,then open it around an inch or two,do this a few times,you should hear a clicking sound,if it isn't clicking the lid switch is broke,i'll send you a video from utube but it's for a different lid switch but you take the machine apart the same way but it's for a 247 lid switch and you need a 279347.if you can hear the motor running and this is happening you could have broken the motor coupling and i'll send that along too.http://www.youtube.com/watch?v=MFsvLiuTniU this is for the lid switch copy and paste.this is for the motor coupling http://www.youtube.com/watch?v=9K1KHEogf3c hope this helps salde
Sep 04, 2011 | Kenmore Washing Machines
Washer stops working after first fill
is it a kenmore?if so open and close the lid,if you don't hear a clicking sound when you close down the lid the lid switch is broken,it's a safety so you can't run the machine with the lid up,if the switch is broke it kills the power to the washer.next time send the model number and let me know how you make out
Nov 04, 2010 | Washing Machines
Lid on washer must be dropped closed in order to jar the machine enough to get it started.
you will need to check out the lid switch, it is probably dislocated or broken altogether. not an expensive repair, can likely do this yourself.
Oct 15, 2009 | Maytag Performa PAV2200
Kenmore Elite Oasis 27062, the lid lock broke
Simply attach both wires from the switch to jumper.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
How do I replace the lid switch on my waher it's a Roper
buy a replacement switch and the top lifts off from the front.  It could be the switch has only come loose or the probe on the lid has broken off.
Feb 27, 2009 | Roper RAX4233PQ Top Load Washer
Will not drain water after washing
it sounds like your lid switch ic either broken at the lid or it is non functional open the lid to manually see if it is broken you schould be able to see it visably on the lid if it is broke your machine will not go into spin and not drain
Nov 24, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Not spinning
hi there,
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
* If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt.
To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it
doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn,
replace it--but be sure to check the pump pulley before you change the belt.
* If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin
and may not function at all. The switch is inside the washing machine main housing near the
door frame. Often you have to raise or open the top or front of the washing machine to get to the
switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside
the washing machine main housing near the door frame. Often you have to raise or open the top
or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the
motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts. If a belt is broken or
badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing
machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper
spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the
clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance
repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor. For agitation
the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to
burn out in one direction and continue to operate in the other. If this happens, you need to replace
the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool® have a
transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the
unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized. These components allow the inner tub
to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during
the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch
prevents the spinning action when the lid is up.
* Is there hot water coming through the proper hose? If not, check to see if the screen inside the
water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the
fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so,
completely replace it.
Aug 12, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing machine doesn't agitate
If washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. Note: direct-drive washing machines do not have belts. 1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn't, the belt may be loose or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) Call a repairperson; there may be a problem with the controls or the agitator solenoid may be broken.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Kenmore 24032\24036 Top Load Washer Logo
97 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
