Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
My Poulan Prolink PPB150e will not run. I can get it started by soaking the air filter in the gas/oil mix but it will not run long. When I throttle up it seems to smother (for lack of a better word) the carb and it loses power and dies.
  • 6 Answers
SOURCE: Poulan PBV200 LE
Probably a low compression problem.
Posted on Nov 19, 2008
  • 71 Answers
SOURCE: Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
Posted on May 02, 2009
  • 376 Answers
SOURCE: how to remove the clutch from a poulan prolink
Poulan makes a tool, part # 530031112, with two prongs that fit the grooves on the sides of the clutch. It fits most Poulan saws and trimmers made in at least the last decade. I use a butterfly impact and 3/4 impact socket and turn CLOCKWISE to remove. There should by an arrow and the word off stamped on the clutch This is the tool.... b61de2e.jpg
Posted on Jun 09, 2009
  • 89 Answers
SOURCE: Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Posted on Nov 06, 2009
Testimonial: "Thanks for the help. The gas line was dessolving on the inside and getting into the carb. I replaced the gas line."
MOTORWIZJ
  • 1340 Answers
SOURCE: One year old Poulan weedeater starts right up but
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Testimonial: "good advice "
Poulan pro brushcutter ppb150e is starting but cutting off after a few minutes, why is this?
FAQ Trimmers ' Poulan Pro
www.poulanpro.com > Customer Support > FAQ
If the unit has an on/off switch, move it to the on position (usually indicated by the ... This should happen between 1-6 pulls, but no more than 6 pulls. 7. ... Some units use a carburetor which does not require holding the throttle trigger. ... If you smell fuel after following the starting procedure, assume the engine is flooded.
Poulan Pro Trimmer dies when I give it gas.? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 22, 2007 - If you remove the two springs holding that cover on the muffler off you can ... Put it all back together and you should be able to crank up and cut. ... Poulantimmer PPB 100 JUNK, since new hard to start cannot keep running ... If, it sit with fuel in the carb then it may still need cleaned with some Carb Spray.
[PDF]OM, PPB150E, 2007-01, TRIMMERS/EDGERS - Poulan
Nov 25, 2015 | Poulan Garden
Tip
Trimmer will only run for a few secs then dies out
First, use the same oil and mix it the same from batch to batch, once you have made a batch (gallon or what ever, never add gas or oil to make more, use up the batch to the last drop, then make a new gallon). Be sure the air filter is clean, some are weted with oil to catch more dirt and provide a bit of extra suction, clean and spray it with a spray cookingoil or soak it in oil fuel mix. Next: Look for 3 adjustment screws on the carb. should be three total. 1 screw is for idle adjustment. the other 2 should be close to each other, one is low speed fuel/air mix and the other is high fuel/air mix. Adjust the low fuel/air mix screw until it will idle un-added with the throttle then adjust the idle on the throttle to get a good idle speed. Next adjust the High fuel/air mix until it gets the RPM's you want it to have. It should go from idle to high speed with out hesitation or cough. It should also run with power to cut any weeds or limbs with out bogging out.
on May 30, 2010 | Garden
I have a Poulan Prolink 150E weedeater. One day I was running it and it just stopped. I've changed the plug, thinking that was it, it wasn't. It's getting gas but not fire. Do you have any
If fuel is present and spark is good then it's air. Remove air filter and see if it starts. If so, it's time for a new one.
May 02, 2012 | Garden
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I can't get it started
Check 1. Compression 2. Gas/oil mix 3. Air filter 4. Spark at spark plug. This is just the beginning of troubleshooting a 2 stroke. They develop fuel line problems and carburetor problems and magneto air-gap problems. Critical though is the oil/gas fuel mix that is used. It needs to be fresh and mixed at the correct ratio. Check all these things that you can and post back.
Dec 14, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Engine suddenly quit and will not restart or fire.
Hello. Begin by changing your air filter. If the air filter is dirty or has too much oil in it the trimmer will not start. Next, change the spark plug. Then check the fuel filter inside of the tank to be sure it is not clogged.
Finally, I do have a customer now and then who accidentally puts in the wrong fuel [for instance straight gas instead of the gas and oil mix required]. If this is a possibility, drain the tank and start over with a fresh gallon of gas and a fresh 2 cycle oil mix. Joe
Oct 24, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Lawnmower starts and dies... where is the main jet for the carb?
try cleaning the air filter, then a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season.
Aug 27, 2010 | Poulan "Poulan" Push Mower
I have a p-3416 poulan saw it is getting spark but the saw still wont start
It's not getting gas. Possible wrong mix oil to gas, but not real likely. Possible sat over the last winter with gas in it and varnished. I'm guessing this is the one, more likely than not. take cover and filter off and clean and bag 'em. pour carb cleaner in the carb and soak overnight. Dump out (carb cleaner and old gas)into a sealable jar or can and fill with straight gas and soak an hour and dump into trash gas/carb cleaner. Use a bicycle pump to blow air into carb to dry it. At most use a computer air can. Then start with the right gas/oil mix, prime it, set the trigger and choke and drop start. (It helps to have the spark plug out during the soak. Then clean it and sandpaper the gap and the magneto area on the flywheel).
Jun 18, 2010 | Garden
Was working fine, then started to work at half force then just quit. Good fuel supply.
Try checking the fuel filter and try the air cleaner, if this is a mixed gas rig you may have the gas mix wrong. Pull out the spark plug and look to see if it's wet. if it's wet you have to much oil, if it's a 4 stroke you have a air problem, after cleaning out the air cleaner and drying the plug ans lightly sand the tip of the spark plug and wash off, try starting it, if it starts and runs your good to go, be sure the governor control arm has not fallen off the governor control arm. If you need more help just post a reply back.
Nov 22, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Gets hot, sizes up.
Clean carb. Pull apart and soak in carb cleaner. Blow dry with air nozzle. Make sure air filter is clean and plenty of air. Make sure spark plug is not gapped wrong and running to hot. Make sure oil/fuel mixture is accurate
Nov 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
601 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
