Question about Linksys WRT160N Wireless Router
NAT type strict, I need NAT type open? - Linksys WRT160N Wireless Router
  • 550 Answers
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
You have WRT160N router. this router has issues with the firmware.
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Posted on May 02, 2010
govinda123
  • 2263 Answers
SOURCE: bt home hub change my nat from strict to open
you will need to change some settings on the router.
reduce the MTU. If the MTU settings is1500 then change 1365.
also you will need to open the some ports on the router.
Click Here for more info
Posted on Dec 04, 2009
Joed911
  • 4338 Answers
SOURCE: Change NAT to open
Open an Internet Explorer browser page.In the address bar type - 192.168.1.1
Leave username blank & in password use admin in lower case...
Click on "Applications and Gaming" tab and then click on "Port Range Forwarding" subtab...
1) On the first line in Application box type in ABC, in the start box type in 88 and End box type in 88, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
2) On the second line in Application box type in PQR, in the start box type in 3074 and End box type in 3074, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box...
3) On the third line in Application box type in XYZ, in the start box type in 53 and End box type in 53, leave the protocol as both and under ip address type in 192.168.1.20 and check the enable box and click on Save Settings...
3) Once you return to the set up page click on the Security tab and uncheck Block Anonymous Internet Requests and click on Save Settings...
4) Click on set-up and change the MTU Size to 1452 and click Save Settings...
5) Goto the XBox Network Settings and IP Address Settings and select manual IP Settings and assign the following on your Xbox
IP Address :- 192.168.1.20, Subnet Mask :- 255.255.255.0, Default Gateway :- 192.168.1.1...
6) Also assign the DNS Addresses on the Xbox
Primary dns :- 4.2.2.2...Secondary dns :- 192.168.1.1
7) Turn off your modem, router, and Xbox...Wait for a minute...
8) Plug the modem power first, wait for another minute and plug the router power cable, wait another minute and turn on the Xbox and test it...it will connect... Kudos! Thanks! If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 05, 2009
  • 138 Answers
SOURCE: i need to change my nat type from strict to open
This router does not have the typical "strict or open" NAT types. Looking at the manual, it looks like what you want is NAT enabled and SUA only enabled.
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906173729&ModelIndexflags=0,420041221102511,420041221102520,420050117110858,420050117110916,420050117110934,420050831093216,420050831095441,420060420160946,420060420161739,420060816160116,420080815092146,420090427144843
Page 133 has the details.
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Posted on Nov 18, 2009
govinda123
  • 2263 Answers
SOURCE: ok my nat type is strict and i am trying to change to open
You want the NAT open for X-box ?
For X-box you will need to open some ports on the router.
Also you will need to reduce down the MTU on the router to 1365.
That will work.
for this you will need to open the router set up.
Click here for more info about x-box and router settings
Posted on Dec 10, 2009
govinda123
  • 2263 Answers
SOURCE: dlink dir-615 change nat from strict to open
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Posted on Jan 12, 2010
I won't to change my nat type
You will need to change the firewall settings of your router. If your Internet service provider is DSL then make sure that modem is in bridge mode. How to change NAT type to open
Nov 29, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do I change the NAT type from strict to open so i can play xbox 360 I have a Belkin 3D54 router
There are several things you need to configure in order to change your NAT to open. Here's a link to help you out:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
It has steps that can help resolve your issue.
Mar 27, 2011 | Belkin Office Equipment & Supplies
My nat settings are strict and I don't know how to change them to open?
Using your Internet browser, you can access the Router’s Web-Based Advanced User Interface. In your browser, type “192.168.2.1” (do not type in anything else such as “http://” or “www”). Then press the “Enter” key.
You will get a set up page where you can disable NAT
Follow me on Twitter
May 20, 2010 | Belkin (F5D8231-4) Wireless Router...
Dlink dir-615 change nat from strict to open
Jan 04, 2010 | NetGear DGN2000-100NAS Router
Ok my nat type is strict and i am trying to change to open
That will work.
Dec 09, 2009 | Actiontec Computers & Internet
I need to change my nat type from strict to open
Log into router
go to the NAT tab
Enable NAT
Enable SUA only
Apply the change.
Nov 18, 2009 | Zyxel P660HW-D1 Router
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
Strict NAT?
If you call microsoft, and tell them that your NAT is strict, they will tell you specific ports you will need to forward. (For Free). If you arent sure how to forward ports, call up your routers manuafturer, or send me another message. I have forwarded my ports as well.
Apr 20, 2008 | Belkin Wireless-N Wireless Router with...
Change NAT to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Oct 08, 2007 | Zyxel P660HW-D1 Router
Linksys WRT160N Wireless Router  Logo
892 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
