Question about Cobra 29 LTD CB Radio
No out power or no signal back but meter wiggle
Its like i cant get out a signal nothing
  • Melanie Rogers May 11, 2010
    What kind of radio are you using? And if its a cobra or uniden have you tried a different mic?
    Champion:
  • 219 Answers
Have you tried another mic, on cobra and unidens you have to have a good mic for them to work.
Posted on May 08, 2010
Truth b2030a studio monitor has power, but no sound?
Did you buy the second hand and with which gear do youvconnect them
Jul 22, 2014 | Behringer Truth B2030A Speaker
Shifter stuck in Park after replacing key switch
Did the lock pin fill one of the slots on the lock plate just under the turn signal switch? Try wiggling the steering wheel while while turning the key. That sometimes helps relieve pressure on the lock pin.
Feb 21, 2014 | 1991 Ford F150
1996 toyota t 100 wont turn over
can you be a little more specific about the neutral safety switch?
Aug 15, 2017 | 1996 Toyota T100
No power ig when turn key
old posts zero answers. what year, no year stated.?
great post, Key does nothing" clear
and is called NO CRANK, if it cant crank it cant start (m/t push starting might)
any time its a no crank,
check ALL FUSES.
1: if A/t wiggle gear shift (P then try Neutral) N might work.
2: if M/T , wiggle clutch , near floor pressed.
if CEL lamp is dead, key on, the fuses are blown.
the CEL must glow key on, or Fuses blown.
easy huh?
Sep 22, 2013 | Honda Passport Cars & Trucks
Sansui A-909 LED indicator(peak power meter)
Check you have 14 volts on pin 3 of the driver chip for the meter.
Apr 05, 2017 | Audio Players & Recorders
2001 buick regal 4 door - headlight flicker on and off. If they go all the way out, you can get them back on by kicking under the dash right above the brake pedal. I removed the cover but cant locate the...
Have you tried wiggling the turn signal lever when the problem occurs? I have seen multiple cases where the wiring inside the headlight high beam/turn signal switch melts and causes the problem you are describing. If you can wiggle the high beam/turn signal switch and CAUSE the problem, you have a defective high beam/turn signal switch.
Aug 05, 2011 | 2001 Buick Regal
Whenever i plug my hdmi or av jacks into my tv, it says no signal
Thanks for choosing FixYa and welcome. You probably have a bad wire. You can try to wiggle the wires and see if you can catch a signal. You may need new ones. Make sure the outlet is working though. If so, hook the wires up and test them with a voltage meter to see if they are getting power.
May 23, 2011 | Sony Playstation 3 (PS3) Console
The speakers on my monitor dont work but if i plug headphones in th back of my computer i have sound.had sound in the eveningbut in the morning had nothing is my moniter dead??
First try wiggling and twisting the the mini jack in the socket, that feeds the monitor speakers signal.
Both ends.. at the PC and at the monitor. Hopefully it's that simple.
The other thing to check is - Do you have a seperate power supply for the speakers? Ck it's still plugged in, to the power, and to the speaker feed.
Test the output with a meter to see if it failed. This can be replaced. (Would be cheaper to buy new speakers)
IF no joy at this point, it possible the speaker circuit in the monitor has failed, or the internal power feed to the speakers (if no external one)
Replacement external speakers are not at all expensive, unless you really need Hi Fidelity. That seems unlikely, as you are using monitor speakers which are as poor fidelity as most come.
I'll bet a $25 set of external speakers will sound 10 time better than the monitor ones.
Feb 10, 2011 | Computers & Internet
Hp a1712n shut it down and will not turn back on nothing happens when you hit the switch
Either your power switch is not working properly, your motherboard is not sending the proper signal to the power supply, or your power supply is not coming on when it receives the signal from the motherboard. Most likely is failing power supply, but test your switch with a multi-meter, then test the signal coming to the power supply. You will have to look up the pin-out on your model, can't tell from the documents whether it is a 20 pin or 24 pin power supply connector to the motherboard.
Jun 07, 2009 | HP Pavilion a705w PC Desktop
Cobra 29 LTD CB Radio Logo
62 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
