Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Hard start tb475ss troy built weed wacker when i close the cold start lever it starts but its 75 degrees out its like the primer ball is inop but i see fuel moving through the lines when priming did not see any plugging in carb ? possibly i missed something.it does run ok after it starts.
    Scholar:
  • 47 Answers
These 4 cycle trimmers need to be primed 10x before a cold start. The bulb will feel *firmer* on the last two or three depressions and you'll know that the carb is primed.
Full choke and and full throttle on first tug should see it hit once with a puff of smoke. Second start attempt should be in choke position two (half choke) and with full pressure on the throttle. Should rev to life on start attempt. Let the engine IDLE for 30 seconds, moving the choke to off at the end of the waiting period. Let engine idle to warm another full minute with no choke, then set to work!
Posted on May 10, 2010
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
Primer bulb will not prime
Hello Tony Galvan, I had to replace the fuel lines to keep from sucking air when I pressed on the primer bulb. Also, I took the carburetor apart and found the gasket was good by holding it up to the sunlight, no light came through indicating holes in the gasket. Then I took a magnifying glass and looked at the bottom half of the carburetor and noticed that a soft film of what looks like lint from a dryer had accumulated on a screen mesh type of filter. Once I cleaned the debris away, the weed wacker started every time. I pulled with a full choke and partially wants to start. Then moved the choke to half choke and pressed on the throttle fully and pulled, it started! But you must at least hold the throttle close to full until 10 seconds for the engine to warm up. Then move the choke to idle. Hope this helps.
peterjb1
May 29, 2013 | Weed Eater SST25CE Gas Trimmer
My troy bilt weed wacker started to make a rattling noise from the engine a couple of weeks ago. Now the head has stopped turning, it appears that the drive shaft is not turning.
sounds like something came look in the clutch assembly. you have to remove the shaft from the power head and take a look inside the cover.
May 30, 2011 | Troy-Bilt Garden
Weed wacker wont start
Try a new spark plug or checka and see if it is getting fuel
Jul 18, 2010 | Troy Bilt Tb70ss Gas Trimmer
Whats the valves set at on a tb475ss weed eater
exaust is set to .013 to .016,,,,,,
intake is set to .oo3 to .006......
i hope this does the job for you,,,good luck
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weed wacker runs then quits and won't start for hours
Sounds as if the issue is related to heat. Possible ignition failure when hot. (I see that alot in my shop.) If the unit is new take it to an AUTHORIZED repair shop and it should cost you nothing. Locate your nearest repair shop HERE.
Hope this is helpful,
Dolf-
Oct 18, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
My TB475SS starts and then dies right away. i
It usually wont idle very well when it's cold, Goto #1 on the choke give the rope a couple of "quick" tugs, and then move it to #2 Give it one or 2 more tugs with a little throttle, now it should be running witha little throttle, let it run like that for a minute then move it to #3 kinda still pumping the throttle a little and it should take off fine. If this is the 4 stroke, mine did the same thing until it was broke in good. (About 4-5 uses), now I have to say its more reliable than any 2-stroke I've owned and I use it commercially. 1st or 2nd pull everytime and is ready as soon as it fires! Hope this helps!
Apr 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
411 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
