Question about Panasonic PT50LCX63 50" Rear Projection HDTV
Red pin striping in picture
After 10-15 mins. a red pin striping goes across the picture
  • Panasonic Master
  • 12,061 Answers
Hi Russ, I cant seem to remove the battery from the TomTom gps... :-( it also shows a picture with a red hand and a stripe across it (to say I shouldnt remove it)... what do I do now??
The battery in the TomTom GPS device is not (readily/easily) consumer removable - replaceable .. i.e. it is not like how you'd replace a battery in your digital camera.
Are you removing/replacing it because it no longer hold a charge ? If so, consider sending it to TomTom ... and they'll do it for you.
That red hand and a stripe across it is usually a warning ... that the GPS device has malfunctioned, e.g. the memory/software/data is corrupted/damaged.
Jan 29, 2014 | Tomtom GPS
My monitor goes half red pin striped and black w/ some visibility
It sounds like you may have connections problem (loose or dirty contacts) between the LCD panel and the logic board, look for that first, worst case will the LCD controller (T-CON) board, which is part of the LCD screen panel assembly. See some pictures here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
Apr 04, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Red stripe across the top after lamp replacement
I have the EXACT same problem with the same model TV. I just searched online to find a solution and found this post. If anyone knows the answer, please let us know. Thanks!
Jan 21, 2010 | Sony Grand WEGA KDF55E2000 55" Projection...
Toshiba eStudio 2830c-getting a light line across
Hello sir; Is the stripes allway in same place and you use document feeder to copy, then you have to clean up a piece stripe glass on the plateform, otherwise ,you have to change drum cleaning blade or drum cartridge.
Dec 24, 2009 | Toshiba Office Equipment & Supplies
I need wiring to install a new radio in my 2001 f-150 acc-battery-ground what are the colors ?
Abbreviations used :
CJB ( aka Central Junction Box, cab fuse panel )
BJB ( aka Battery Junction Box, Engine Compartment fuse panel )
In the factory connector :
Hot at all times from CJB Fuse #1 is pin #9, light green w/ violet stripe wire
Hot in start from CJB Fuse #20 is pin 3, Red w/ black stripe wire
Hot in Accessory or run from CJB Fuse #8 is pin 10, Black w/ Pink stripe wire.
Grounds in the connector :
pin 2, black
pin 11 black w/ light green stripe
pin 16 black w/ light green stripe.
pin #1 light blue w/ red stripe is the instrument illumination, after the cluster dimmer switch.
I would stay away from using the black w/ light green stripe, I seem to recall those are the shields for the speaker pairs.
Bit late on the reply, just caught this one. If you don't have it don't, good luck
Sep 30, 2009 | 2001 Ford F150 Styleside SuperCrew
No picture. Red-blue stripe across screen
there is a computer chip that is now toast on your motherboard. I don't remember the name of it but same happened on my RCA. It is caused by over heating. Over heating is caused by lousy vent design. Its important to place TV on hard surface NOT CARPET. I learned the hard way. The chip that went out is a $15 - $20 part, but finding someone to put it in for cheap is like winning the lotto. hope this helps.
Jun 24, 2009 | Televison & Video
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Stripes across viewing screen
almost sure this is cause by flex circuit in the zoon lens that is damaged and need to be replaced. Almost always the problem of stripes in the picture is worst when you take pictures in full zoom mode because in this position of the lens the flex circuitis is fully streched. Thats all folks
Jan 19, 2009 | Nikon Coolpix 8700 Digital Camera
Panasonic PT50LCX63 50" Rear Projection HDTV Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
