Question about Radio Communications
I'm having problems programming radio frequencies on my scanner.
The radio frequencies in my county have three numbers, a decimal point, then five additional numbers. My scanner is only allowing me to program three numbers, a decimal point, and then four numbers. I figured that because the last number is always a zero, that maybe it doesn't matter if you include it or not. Once I enter the frequency, it just says error.
    President:
  • 2,761 Answers
You didn't mention the make or model of your scanner, so I can't provide a response specific to your unit, but the trailing zero is meaningless, so there's no reason to enter it. Some bands on some scanners will only accept three decimal digits, but the scanner should round off your entry and still receive the intended frequency.
Bill B
Posted on May 02, 2010
How do I program a realistic 2029pro
These steps were listed on their website:
PROGRAMMING CHANNELS
1. Turn on your scanner by turning the volume clockwise.
2. The scanner might start scanning. If so, press MANUAL to stop the scanning.
3. Enter the channel number that you want to program and press MANUAL.
4. Enter a frequency including the decimal point. The decimal point shows up on the display as a -- (dash).
5. Press Enter to store the frequency.
6. To confirm the proper entry, press REVIEW. The programmed frequency appears on the display one digit at a time.
7. To program more channels repeat steps 3-4. (IR-07/29/96)
Nov 11, 2014 | Radio Communications
Cant get any frequencies to program
hi select a bank ,Press Hold. Then enter the channel number where you want to store a frequency, then press Func and Pgm. The channel number appears. 2. Use the number keys and to enter the frequency (including the decimal point) you want to store. 3. Press E to store the frequency into the channel. Notes: • If you entered an invalid frequency in Step 2, Error appears and the scanner beeps three times. Enter a valid frequency. • The scanner automatically rounds the entered number to the nearest valid frequency. For example, if you enter 151.473 (MHz), your scanner accepts it as 151.475. • When you enter a frequency into a channel, the scanner automatically turns on the delay function and DLY appears. When delay is turned on, the scanner automatically pauses scanning
Mar 18, 2011 | Uniden BC72XLT Handheld Scanner
Please tell me how to program in my county scanner frequency numbers .
To enter a known frequency into your BC92XLT:
- Power the scanner ON
- Press the HOLD key
- Enter the number of the channel that you wish to program (1 through 200)
- Press the FUNC and PGM keys
- Enter the frequency, including decimal point (e.g., 155.455)
- Press E to enter the frequency into the scanner's memory.
More detailed programming instructions can be found in the factory user's manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Oct 08, 2010 | Uniden BC92XLT Handheld Scanner
I need codes for my scanner? but it only lets me put in 6 numbers and i cant fined these code for Gloucester county nj fire dispatch
Hi, my name is John. Get your frequencies here www.RadioReference.com .....Are you including the decimal point when programing.....hope this was helpful....Rate this solution on the four thumbs-up....John
Jul 14, 2010 | Uniden BC72XLT Handheld Scanner
Ki need help programing my p that i bought used also i olnly have some of thehcodes for toulare county (porterville) thiat is where i live.... can yuo help me? thanks, kary ro 82 scanner
Before you start programming you'll need a list of frequencies (not codes). For a comprehensive database of active frequencies in your area, visit:
That site also contains a lot of other useful scanning data, including links to users groups.
To program a known frequency into the scanner:
1. Power the unit ON.
2. Press the PGM key.
3. Enter the desired channel number (1-200).
4. Press PGM again.
5. Enter the frequency, including the decimal point (ex: 462.365).
6. Press ENT to enter the data into memory.
7. Repeat steps 2-6 for other channels.
More detailed programming instructions can be found in the scanner operating manual which you can download/print here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B
Jun 29, 2010 | Radio Shack Pro-82 Scanner
Can't program numbers in it the scanner
Press PGM, then enter the channel you want to store a frequency, then press PGM again, use the number keys including the decimal point you want to store, then press ENT to store the frequency into the channel....you can get your frequencies for your state at www.RadioReference.com ....hope this was helpful
May 03, 2010 | Radio Shack Pro-2018 Scanner
I need help programming my Pro 97 to listen to fire/police channels in Kitsap County washington
Press manual,enter channel number,then press manual,enter the frequency you want including the decimal point,then press E,if you make a mistake press CLR twice to erase. You can get the frequency,s you want at RadioFreq.com ...hope this helps...
Mar 16, 2010 | Radio Shack Pro-97 Handheld Scanner
How do I program my Uniden BC72XLT race scanner?
1. Press HOLD. Then enter the channel number
FUNC and PGM. The channel number appears.
to store.
Notes:
ERROR appears and the scanner beeps three
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Nov 02, 2009 | Uniden BC72XLT Handheld Scanner
How do i program my realistic pro-2025 scanner
scanning.
Jun 03, 2009 | Radio Communications
Programming Bearcat BC 55XLT Scanner
Ok doc, I'll see if I can walk you thru this as there don't seem to be a manual available for download.
* Push manual button and bring it around to channel #1
Enter the freq including the decimal point. Push the E button to enter the freq into the first channel.
* Push manual again and move to channel #2 and repeat.
If you need some new freq's for your area, go here, click on your state, county, and it'll give you a complete rundown.
http://www.radioreference.com/apps/db/
If you need 10 codes for your area, go here and click on your state.
http://www.nat-com.org/radio.htm
If you need anything else, let us know,, Mechanic
Feb 19, 2008 | Radio Communications
Radio Communications Logo
116 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
