Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
I own an FPD1730 17 in. Flat Panel Monitor. My screen is dim and I'm unable to manually change the tints back to the way it was. I have tried autoset on my monitor screen but it changes back to dim and will not default back to autoset. Is my monitor going out on me??
  • 1,768 Answers
This a micro-controller issue and a tech need to replace components that regulate the voltage to the florescent tube that excite the LCD to give a picture. they are sometimes call a LCD controller. This is a main board problem.
Posted on May 02, 2010
Testimonial: "Thank you for your assistance on this issue. "
    Problem Solver:
  • 15 Answers
You may want to try giving eztune a shot. Its a software that lets you truley set your color, contrast, brightness to where its supposed to be. Its free, so your not going to lose anything. Here is the link http://www.portrait.com/dtune/gwy/enu/upgrade.html. Good luck, I hope it helps.
Posted on May 03, 2010
SOURCE:
FIX THE COLOR, IT HAS A GREEN TINT THAT DOESN'T GO AWAY WHEN TRYING TO ADJUST COLORS FOR DISPLAY DON'T KNOW WHAT CAUSED IT
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 19, 2015 | Sony BRAVIA KDL-40EX523 40" LED TV...
Entire screen has a pink tint. Can change to blue with settings. Cannot change to natural with tint etc.
Check that all cables are intact and plugged in correctly.
Turn of the TV completely. There might be a manual button on the tv for this. As the last thing, remove the power cord from the power outlet in the wall or where it is placed. Wait 1 min. Then put it back in, swith it on and turn on the TV again.
If this doesn't help and you have tried replacing the cable that you get the picture from (VGA, DVI, Antenna etc.) then it is most likely broken.
Jul 06, 2014 | Sceptre X400BV-FHD 40 in. LCD TV
Black color screen
Change your screen resolution to the highest setting first, in control panel, appearance/ themes. Next Push smart button on bottom right of monitor. Cinema mode should be highlighted hit autoset on monitor. Next hit the FUN button and highlight the 4:3 screen setting. This will expand your image to fit the screen without giving it that stretched and distorted appearance.
Jul 18, 2010 | LG W1953TPF 19" Monitor
I'm afraid my monitor is failing the picture
This is due to problem with the monitor circuit board. Need to repair the same with the help of local expert engineers or service center experts if you have warranty on the monitor.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Mar 03, 2010 | NEC LCD1712 17" Flat Panel LCD Monitor
Normal screen is white background, but lately I am getting a blue tint that clears up sometimes and sometimes not. Please advise
Try hooking up another knowng working monitor to the computer and see if the blue tint comes back intermittently.
If it still comes up then you know your video card is the culprit. If the blue tint goes away then you know the original monitor is bad.
Aug 04, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor dims on a black background hanns G 28
Go into monitor settings and turn "off" X-Contrast. X-Contrast will auto change contrast when backgrounds darkens. However, adjust manually the Brightness and Contrast settings to compensate.
Apr 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Dell - 17" flat screen
This sounds like the back light is gone on the monitir... to check this look very close at the monitor whet the PC has booted, if you see a VERY dim image on screen then it suggests that the back light is gone.
Many monitors hace a 3 year warranty so I would try a warranty claim before throwing it away
Jul 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor problem
Check the cable wiring make sure all is plugged up right, If you have rebooted and it comes on ok than its the power cord. Remove and re-plug again
Nov 29, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor displaying yellow tint
Try this. Worked for me immediately, including with PhotoShop
  1. Go to Color Management (in Vista, just click the Windows Orb / Start Search & type in Color Management)
  2. On Devices, select your display (repeat if you have multiple ones... at least I did). e.g., Syncmaster ....
  3. Check the box: Use my settings for this device
  4. Select any and all profiles you have and Remove them.
Check to see if that fixed it. You may need to restart. I didn't have to.
more info, and where I learned about it here:
http://www.mydigitallife.info/2007/07/11/windows-vista-photo-gallery-yellow-tint-background-problem/comment-page-2/
http://www.walkernews.net/2008/07/15/how-to-fix-windows-photo-gallery-yellow-tint-and-photoshop-monitor-profile-problem/
Nov 27, 2007 | KDS Radius RAD-7 17" Flat Panel LCD...
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
360 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
