Question about Garmin Astro 220/dc20 Tracking Collar Cable Antenna
Astro 220 garmin collars drop out will not
Astro 220 garmin collars drop out will not pick up untill you get close
3 Suggested Answers
SOURCE: hi, my new Garmin Astro
Did you get this problem resolved?
I am having the same problem, could you tell me what your solution is/was?
Thanks.
Posted on Oct 09, 2011
SOURCE: hello! i bought 4 collar dc40
UPDATE THE COLLAR,ONE OF MY COLLARS WAS DOING THE SAME. AS SOON AS I UPDATED IT ,IT WORKED FINE
Posted on Nov 24, 2011
My Garmin Astro 220 will not pick up collars dc30 or dc40 outside 50-100 yards. I have updated all to newest 4.0. still not working. Any advise I have tried everything!
Try this:
  1. Power your Astro 220 ON
  2. Press DOG button
  3. Press MENU button
  4. Select DOG LIST
  5. Select the name of your DC 30 from the list
  6. Select SHOW INFO
  7. Press MENU
  8. Select CHANGE COMM. SETTINGS
  9. Choose OK
  10. Change your update rate to 5, 10, or 30 seconds
  11. Choose OK
If your update rate was set to 0 seconds, changing it to 5, 10, or 30 seconds will now allow for your DC 30 to communicate consistently with your Astro 220.
Aside from that, most problems with transceiver range relate to background interference, antenna/transmitter damage, and battery life.
Nov 17, 2012 | GPS
I own 15 garmin dc30 collars and when hunting they are spred out in no specific order over 3 astro 220 hand held units. I am having trouble receiving all of the collars. On one unit i may pick up for...
Hi, thanks for posting your Question..
At times you may experience Problems with a Garmin Astro DC30 Collar. I've heard And experienced reports of the following problems with Garmin DC 30 Collars
Before trying to do a Hard Reset for the Garmin Astro 220 DC30 Collar you should try and identify if it is the collar or the 220 Receiver. the easiest way you can do this is to check your Tracking System with another collar. If the second collar works fine then you can assume that you DC30 is not working as it should.
First i would Check all the basics, make sure the collar is charged.
I also would Delete and Re establish the Dog Collar in you system by going to the Dog List on the menu of the Astro 200, I would probably recommend Resetting the 220 receiver since it is much easier to reset that than the Collar.
Lastly, If these do not fix your problem you should try to "reset" the DC30 by
Removing the Back Plate (silver piece)
While Your looking at the connections for the two antennas, I would check to make sure there is nothing wrong with both the GPS antenna connection, and the VHF Antenna on the collar. Personally I carefully disconnect each and make sure they are both clean and free of Debris and Junk. (good Solid connection here will only help the performance of the collar) You can carefully use a brush or electronics contact cleaner for the VHF antenna (Screw mount) (See images below). I would not put anything into the SMP (square Antenna wire connector)
Removing the VHF Antenna on a DC30
Clean this before re-installing. Very Important to have a good Electrical connection3. Remove the Four Small Philips screws on the outside of the case to access the battery and electronics compartment. Very Carefully Disconnect the white battery connector from the board (see images below). Leave the battery Disconnected for about 15-20 minutes for a full reset, Reconnect it to the board.. (CAREFULLY) Here you Can see the battery Connector for the DC 30 Garmin
Different Angle of the connector for Dc30
As you re-assemble the Garmin DC30, Clean all seals and clean antenna connections.
Clean all seals and connections before re-assebling the Garmin DC30 collar
That is A Garmin DC30 Reset Instructions, and Many times when you are having Problems with Garmin DC30 collars this is the First step Garmin will ask you to do before sending them back.
Here is how to Mark a Location other than your location. For example You might want to mark the Tree before you get to it in case your dogs leave the tree. Most of the time If you are like myself You want to Scroll over and Hit the Mark Button, However that will just Mark Your current Location and not the location that your cursor is.
Here are the instructions To mark a location where your cursor is on your Astro 220.
Press map
Scroll the cursor over to the location you want to mark.
Press (ENTER) instead of pressing Mark.
If you press Mark it will mark your current location..
After you press enter.
It will either Select something that you've scrolled over and you should be able to save that as a Location, (Hint: you can change the name to what ever you want before you save it.)
Or if it doesn't select something it will say "no Map info at this point. Do You want to Mark a location here"
I know it's pretty confusing and counter intuitive, But that's how you can mark a location where you are not at.
If your Antenna's are not too OK,you can get a replacement from the below link:
http://garminastrodog.com/garmin-astro-dog-tracking-antenna-questions/
http://www.hdssupplies.com/garmin.html
Good luck and thanks for using fixya.
Jul 12, 2011 | Garmin Astro 220 GPS
Hello! i bought 4 collar dc40 for astro 220. one of them have a problem: the light is red and fix: what happend?
Dec 07, 2010 | Garmin DC 40 GPS Dog Tracking Collar
If your collars a stolen form your dog can the theif program them to his handheld
yes it takes about 5 seconds to program in a new collar. My friend and I track each others collars when we go hunting.
Jan 04, 2010 | Garmin Astro 220 GPS
Astro 220 and dc 30 not reciving each other dog trackers both have full sat but reciver is not piking up collar can you help
after some thort i re aqainted my astro 220 and dc 30 again.
this was done at factory and i still dont no why it has done it in the first place, but i got it going again.
on the 220 you can add aditional collars so i went into add a new collar and followed the proccess
and it re astablished it self with the colar.
now i took it on a hunt with my dog yesterday and seemed to be working fine it was traking my dog like it was suppose to.
my dog took of and was been track then lost signal.
after some time i found my dog and noticed the dc 30 had lost its satilite link the red led lites were only blinking not double blinking like there ment to when they have a satililite link.
thort it mite have been out of range but got back into town and it still is not picking up satilite.
so can you please tell me why this is so.
ordered this unit all the way from america to australia and not haveing much luck or very impresed.
so anything you could tell me would be great. had this unit 3 days used it once.
reguards john guppy.
Nov 28, 2008 | Garmin GPS
Garmin Astro 220/dc20 Tracking Collar Cable Antenna Logo
57 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
