Question about Onkyo TX-SR607 Receiver
Lost colors when using composite cables with Wii
When attaching any components with composite cables(red, white, yellow) like a dvd player or my Wii have of my colors are missing. When I play golf the sky is a purple grey. Same goes for a movie on a dvd. But when I use and HDMI connected dvd player I have no problem. I'm using an Onkyo TX-SR607 with an HDMI out to an Optoma HD71. It doesn't matter if I use component cables or composite still get same results.
    Problem Solver:
  • 6 Answers
Puedes subir o bajar la resolucion de tu t.v o pantalla ya que algunas son HDMI u otras FULL HD probablemente no este bien ajustada o los cables no estan funcionando bien o estan trozados,....
Posted on May 02, 2010
HOW TO CONNECT
You have 3 options coming out from the DVD player:
1) Composite (Yellow, White, Red)
2) S-Video (Round and Black)
3) Component (Red, Green, Blue)
Composite is the easiest, as both video and audio are taken care of through the 3 connectors.
S-Video has slightly higher quality, but is largely outdated and requires a separate audio cable.
Component has the best quality, but also requires a separate audio cable.
If you have a composite cable (it should have come with the DVD player), then just hook up the Yellow/White/Red cable from the back of the DVD player to the same color connectors on the back of your TV.
S-Video and Component connect in the same manner (respective color to respective color), but you'll need to determine whether your TV can support a separate audio input or not.
Jul 12, 2012 | Yamaha DVD-S540 DVD Player
How do i connect my nintendo to my samsung led tv
I am assuming that you are talking about a Nintendo Wii.  When you buy a Wii it comes with standard RCA composite cables that are three colors, Red, White and Yellow.  Yellow is the cable that carries the video signal and the red/white carry the stereo audio signal.  You would need to connect these cables into the corresponding color inputs on your tv.  Plug the yellow ended cable into the yellow jack on your TV and do the same for the red and white cables.  After this is done, you will need to switch your tv's input to the input that corresponds to the one you plugged those cables into.   Some newer flat panel TVs do not come with RCA composite inputs.  If this is your problem, you will need to get some component cables for your Wii.  These cables look identical to RCA (composite) cables but come in colors red, green, blue, red and white.  In this case the red, green and blue cables carry the video signal and the red and white carry the audio.  You can purchase these from just about any store that carries the Wii or online from places such as Amazon.com.
http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
You would hook these up the same way by matching the colors and then changing your tv to the corresponding input.
Hope that helps!
Jun 27, 2011 | Computers & Internet
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
How do i connect my dvd rv32 to my sony tv?
It will depend on your TV's inputs. The included cable is a composite A/V cable. This will work. Match the RCA plugs on each device (yellow to video out on the DVD player, video in on the TV; white and red audio go similarly). Alternatively, you can get and use an S-video cable.
For a better picture if your TV has Component video, get a Component video cable (this has three RCA jacks colored red, green and blue on each end) and then use that. You can get a separate audio cable that only has the red/white RCA jacks (or use the composite video with the yellow video jacks dangling).
If your TV doesn't have Composite video inputs, you need a RF modulator (Composite to RF converter). These are available at many sites, including Radio Shack.
I hope this helps.
Sep 06, 2010 | Panasonic DVD-RV32 DVD Player
The only connections that work are the component cables(color stream, RGB-Red, Green, Blue) which I understand is a better quality picture but the connections for my DVD player are RCA (Composite - Red,...
You'll need a DVD player that has component outputs. The composite carries the entire video information, while the component sends the three different color signals separately. The red and white cables are output cables. No all DVD players have the component outputs.
Jan 27, 2010 | Hitachi 43FDX01B TV
Trying to hook up the dvd player to the tv and I figured out how to get the color back on but the sound is terrible it sounds like its echoing. Can't figure out the blue green red combination for white red...
Your TV probably has several different ways of connecting video. One is component, which uses three cables. They are red, green, and blue (RGB). The video output on your DVD player will match this color scheme.
Another scheme for video is composite (because it combines the red, green, and blue into one cable). Composite video is usually a yellow "socket". It is simpler to connect, but the video quality is noticeably poorer than component (RGB).
Another scheme is S-Video. This is one cable (round and black), but you will see four pins inside the connector (and four holes in the "socket"). This accounts for the three cables in the component scheme with the convenience of having only one cable. The picture quality is almost as good as component as well.
In your case, there may be confusion between composite and component. If you have red, green, and blue sockets on both the DVD and TV, then make sure you use them and connect them color for color.
Now for the sound, this is simpler. Red is the right channel, and white is the left. Make sure you connect red to red and white to white. Then, viola, everything will be right.
I hope this helps.
Aug 24, 2009 | Philips Televison & Video
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Onkyo TX-SR607 Receiver Logo
254 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
